Double Bladed Chain Saw
11 replies to this topic
#1 Alc ONLINE
  • 7,257 Thanks
  • 7,595 posts
Posted February 09, 2014 - 06:55 PM
Has anyone know what this saw was used for ?
http://york.craigsli...4317180392.html
  • MH81 and trowel have said thanks
#2 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted February 09, 2014 - 06:57 PM
Maybe it is used for cutting boards out of logs? What ever it is, it sure looks cool.
  • Alc and oldedeeres have said thanks
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted February 09, 2014 - 07:14 PM
That's an odd one. Can't figure what a use would be unless its like Ryan thinks.
#4 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted February 09, 2014 - 07:28 PM
How far apart are the blades? I agree with Ryan, sounds right anyway!
#5 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
http://www.smokstak....ead.php?t=50855
  • Alc, boyscout862, superaben and 1 other said thanks
#6 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 09, 2014 - 07:32 PM
:ditto:
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted February 09, 2014 - 07:39 PM
So, it was never meant to have two blades at once. Hmm, interesting.
Moe the bar to the center for normal cutting, move to the outside for close to the ground cuts.
I can see what they were saying about center being better balanced.
  • oldedeeres said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted February 09, 2014 - 07:40 PM
I liked Ryan's idea better than the real answer.  :thumbs:
Ben W.
  • twostep said thank you
#9 Alc ONLINE
  • 7,257 Thanks
  • 7,595 posts
Posted February 09, 2014 - 07:43 PM
Thanks for the answer :thumbs:  Pretty neat idea
#10 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted February 09, 2014 - 08:10 PM
It seems like a good idea, and I am sure it was much better balanced! The only problem is that you need to lean that much farther over to keep out of the way of the bar. Under closer inspection I noticed the bars are worn differently, that goes to show that they where not used simultaneously, at least not for the lives of the two bars.
#11 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted February 10, 2014 - 05:18 AM
From the SmokeStack web site:
The exhibitor said it was not meant to be used with two blades, they just set it up for show with two blades to get your attention, which it does.
Ohhhhhhhhhh, I dunno. It looks like that two-bar setup would work just about right for slicing sausage for a sammich! music.gif
#12 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,549 posts
Posted February 10, 2014 - 07:51 AM
Maybe for cutting wooden wheels :bigrofl:
