Wanted
Onan Parts
11 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted February 09, 2014 - 01:38 PM
Hi all, goes anyone have any onan parts from a fudged motor kicking around that they may be interested in selling? i have a 20hp mid 90s motor and i require a ignition module and the ring, and also the outside flywheel cover, might be interested in other parts also, i got this motor from the po with the flywheel off, he said it was good but we will see once we fire it up, i would need these parts shipped to niagara falls usa but that and payment can be worked out later. i think the onan 16hp and up motors all use the same parts thanks for looking
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 09, 2014 - 03:09 PM
I don't have anything Onan related here.  Contact onanparts.com and see if he does.  He is going to want a model number.
Ben W.
  • farmer john said thank you
#3 olcowhand ONLINE
  • 41,134 Thanks
  • 31,413 posts
Posted February 09, 2014 - 05:05 PM
There are differences in flywheels, so you'll need to be more specific about your model & code off your engine.  That or a pic of the current flywheel.
#4 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted February 09, 2014 - 05:23 PM
Just sold some onan engine parts to a guy in Brampton , he has a flywheel
He just reposted the parts as he only wanted a few parts.
http://toronto.kijij...QAdIdZ565599558
#5 MH81 OFFLINE
Posted February 09, 2014 - 10:51 PM
You might check with each of the site sponsors. They all would have different stock.
For instance, BHTS may have some Onan parts in an old Sears over there. You never know.
#6 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted February 09, 2014 - 11:53 PM
I have these Got rid of everything with an Onan in it so these are leftovers Came from a P220 that dropped a seat
Edited by baerpath, February 09, 2014 - 11:54 PM.
#7 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted February 10, 2014 - 03:07 AM
I just went trough this lesson with the onan engines. Onan used these engines in several different applications so be advised. THEY DO NOT ALL INTERCHANGE!!!!  You WILL find that the onan engines do have some parts that are useable on others but they do not all interchange such as the stators flywheels starters crankshafts etc etc---there are several options and you find this stuff out once you try interchanging parts. My SUGGESTION  is to find a parts manual for the actual engine you have and find original parts otherwise you could be spending money on stuff that is useless to you
#8 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted February 10, 2014 - 06:13 AM
that website, garysplace, that sells onan parts, is a spot to check.  call the phone number or send gary a email about what u need.  He has a shop and rebuilds onans too. I sent him a 16 hp motor off of a case 446 and he did a great job on it.  He might have what you need
#9 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted February 10, 2014 - 09:45 AM
You can also contact Robert at  boomers_influence at yahoo.com
He goes by boomers_influence on MTF and sells a lot of used Onan parts , some new too.
  • superaben said thank you
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted February 10, 2014 - 10:42 AM
And he doesn't know just a little about Onans, he's kinda religious about them. Very helpful guy.
#11 KennyP ONLINE
  • 38,299 Thanks
  • 45,899 posts
Posted February 10, 2014 - 11:04 AM
But you will need a model #!
#12 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 10, 2014 - 07:44 PM
Right you are.  :thumbs:  Many of these guys won't even talk business unless you can give some model info right off hand.  That's because guessing never gets anyone anywhere.
Ben W.
