Bolens Huski Gardener Is Home!
41 replies to this topic
#31 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted March 25, 2014 - 07:11 PM
006.jpg 007.jpg 008.jpg gunstuff1000,
figured out what was wrong here are the pics of the bolens gardener and the simplicity.
Edited by boli51, March 25, 2014 - 07:15 PM.
  • gunstuff1000 and Tbrooks have said thanks
#32 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted March 25, 2014 - 08:31 PM
Tractor looks good! What are you concerned about with the front hitch it appears that your front adapter hitch plate looks correct
#33 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted March 25, 2014 - 08:42 PM
the hitch itself is not equipped with the hooks and star wheel to attach to the bracket under the front end of the tractor. I'll get some picks of that and post as soon as I can maybe tonight.
  • gunstuff1000 said thank you
#34 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted March 25, 2014 - 09:42 PM
. Ok I might have a extra top mount plate with the hand wheel an stuff I will have to look I assume it's the same as the power-ho if someone else knows for sure please chime in?
  • boli51 said thank you
#35 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted March 25, 2014 - 10:03 PM
This is the hitch I have. According to the manual I downloaded it should fit the power hoe and the gardener.
Edited by boli51, March 25, 2014 - 10:09 PM.
#36 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted March 25, 2014 - 10:11 PM
. Ok that's a versa matic hitch that's the issue. Now good thing is of you notice there are two holes on the top you just need the hitch bracket an it will bolt onto the current hitch you have I'm pretty busy right now with work but when I have a chance I will look an see if I have a extra bracket setup you need
#37 boli51 OFFLINE
boli51
  • 37 Thanks
  • 38 posts
Posted March 25, 2014 - 10:26 PM
Thanks for the update. that would save a lot of work.
#38 DougT ONLINE
DougT
    Dog Approved
  • 6,853 Thanks
  • 4,953 posts
Posted May 11, 2014 - 12:40 PM
Bob, Did you ever get pics of the cast rims? I bought 2 cast rims and tires that I thought were a pair of Bolens. The owner didn't know what they were from. After I bought them, I realized that the offset of the rims were different. The rims both have matching remains of orangish paint and the same exact tire. I don't see any Bolens tag but then I think the one rim I have just had a Bolens decal at one time. I'm going to try to look at it today and see if any or all matches. I'm wondering if the spacing on one had to be different for clearance?
#39 chieffan ONLINE
  • 9,573 Thanks
  • 6,411 posts
Posted December 29, 2014 - 09:21 PM
If your rims are rusted to the point they may poke a hole in the tube, you can fix that rather easy.  Clean the rims as best you can.  Remove all signs of any loose stuff, dust, etc.  Mix up a batch of fiberglass resin and using a small stick or similar item, spread the resin over the entire rusted part of the rim.  When it sets up clean off any pointed resin  and you should be good to go.  You will have a nice smooth surface for the tube to ride on.  This works good on the edge of the rim to seal tubeless tires also..  Good luck.
  • Lauber1 and Tbrooks have said thanks
#40 geissenkid OFFLINE
geissenkid
  • 2 Thanks
  • 1 posts
Posted February 10, 2015 - 07:09 PM
I am a new member. I have a barn find bolens huski with plow,
sickle bar and cultivator I've had it for years and your topical
Has made me want to restore thank you good luck
Geissenkid
#41 DougT ONLINE
DougT
    Dog Approved
  • 6,853 Thanks
  • 4,953 posts
Posted February 10, 2015 - 08:01 PM
Welcome to the forum! Feel free to start a thread on your tractor. We'd all like to see pics of it.
#42 MH81 OFFLINE
Posted February 10, 2015 - 09:35 PM
Geissenkid
:welcometogttalk:
