Some Of My Cub Toys!
11 replies to this topic
#1 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 07, 2014 - 03:12 PM
Some of the cub toys.. ImageUploadedByTapatalk1391803830.655666.jpg ImageUploadedByTapatalk1391803847.050794.jpg ImageUploadedByTapatalk1391803863.795692.jpg ImageUploadedByTapatalk1391803874.451764.jpg ImageUploadedByTapatalk1391803888.678667.jpg
My uncles toys ImageUploadedByTapatalk1391803930.215670.jpg ImageUploadedByTapatalk1391803941.850461.jpg
  • MH81, hamman, gopher and 7 others have said thanks
#2 Sawdust OFFLINE
Sawdust
  • 6,019 Thanks
  • 3,495 posts
Posted February 07, 2014 - 08:05 PM
Good looking pullers, like the stacks out the front.
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 07, 2014 - 11:35 PM
Looks like a cool fleet. I know the gentlemen who used to own longshot before he sold it. Are most of your cubs vtwin powered or flathead?
#4 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 08, 2014 - 12:45 AM
Ah u know Bruce wise? He's pretty cool guy! My red 582 is command powered, the yellow gear drive 782 in that pic is flat head kt17, my 582 that says breaks and scatters is Briggs flat head powered..and scraper tractor has a 20hp command in it
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 08, 2014 - 02:33 AM
Yeah he pulled with us for a few years. It seems the flathead class is catching on pretty quick and those briggs and kohlers are everywhere.
#6 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 08, 2014 - 09:04 AM
Really dang we tried to get one here and it wouldn't go.. We had 5 flatheads now 4 years later I'm the only one...
#7 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 08, 2014 - 01:27 PM
I think we have around 10 here in the flathead class. Can you tell us about that stock altered? anything special with it?
#8 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 08, 2014 - 01:50 PM
Aftermarket Midwest super cub block, Midwest crank, steel cam, Rader assembled makin 51hp.. It's a 100 frame with light sheet metal grill 2pc fine spline in trans, hardened top shaft, 21/23 gears hardened pinion holder. 3puck clutch
  • Dieselcubmike said thank you
#9 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 11, 2014 - 03:27 AM
Sounds like you have a pretty good set up. Did you build the motor yourself or have Midwest do it?
#10 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 11, 2014 - 08:21 AM
I had mark Rader build it..I've since sold it... It was to expensive to keep, sold it and used some of the money to get the 882 lol
Edited by searstractorfan, February 11, 2014 - 08:22 AM.
#11 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 12, 2014 - 04:09 AM
Don't blame you. Thought about getting into the alky motors but just not worth the money and having to rebuild them after 10 or 20 runs if that since the alcohol and oil mix. Ended up building the diesel and im glad I did.
#12 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 12, 2014 - 05:55 PM
Have Rader build it, u can take it to 100 runs if u use good oil and don't free rev it at full rpm going down the track.. I had well over 30 runs on the rotating assemble and it looked perfect when he tore it down.. I had him check it out after I had a bunch of my equipment vandalized.. The key is oil and the changes..
