Case 444 Lifts In Rear, But Not In Front, Ideas?
32 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted February 06, 2014 - 07:37 PM
The 3pt hitch in the back lifts up & down perfectly when I move the R&L...HOWEVER nothing moves in the front for the plow to raise and lower. Is it something obvious that I'm missing here?
#2 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted February 06, 2014 - 07:44 PM
Your selector valve
#3 ssmewing OFFLINE
ssmewing
  • 48 Thanks
  • 58 posts
Posted February 06, 2014 - 09:20 PM
You need a plate that goes to the same thing the deck attaches to. They would both move at the same time without the selector valve.
#4 jimbobbillyray ONLINE
jimbobbillyray
  • 2,787 Thanks
  • 2,755 posts
Posted February 06, 2014 - 09:31 PM
and u need the correct lift arm for the plow, and you need to bolt it to the correct hole on that plate.
Edited by James henry, February 06, 2014 - 09:35 PM.
#5 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted February 06, 2014 - 10:56 PM
Here are a few pics of my setup on the '71 444. Sorry for the sideways pics....off to bed so no time to flip'm. Hope these help. BTW, the arm coming from the rear is to my sleeve hitch.
#6 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted February 07, 2014 - 08:04 AM
Weird, I have that plate & connector arm to the plow, yet it does nothing.
Matt, Ill try to match mine up to yours. Ill also post photos.
Thanks guys!
#7 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 07, 2014 - 01:08 PM
Pete if you can Google Case 444 with plow (images), I used Bing but I'm sure Google will have the same images?
Anyway, It looks like the lift rod from the plow goes in the lower right hole in that bracket.
#8 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted February 07, 2014 - 06:50 PM
Did you install 3pt? It should have selector valve and even if it didn't your mid cylinder would move when the rear cylinder dead head. Unless some one took the plumbing away from mid cylinder to run 3pt. If you have a lift bar going to back you don't have 3pt. That be pretty cobbled up mess .
#9 ssmewing OFFLINE
ssmewing
  • 48 Thanks
  • 58 posts
Posted February 07, 2014 - 07:19 PM
Thanks guys!
Has it ever worked?
With the 3pt empty you may have to continue to hold the lever until the 3pt dead ends its travel.
Also your bell crank to mid lift cylinder connection may have failed. Try to see if the mid cylinder is moving.
#10 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted February 08, 2014 - 05:21 PM
Here's my photos of my setup:
#11 jimbobbillyray ONLINE
jimbobbillyray
  • 2,787 Thanks
  • 2,755 posts
Posted February 08, 2014 - 07:38 PM
first, put your lift arm in a different hole, front one at the bottom.  If that does not give enough lift, flip that plate over, bolt it on facing foward instead of back.
#12 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted February 09, 2014 - 01:28 PM
The lift arm was in the bottom front like you said in the beginning, with no luck.
So just flip the plate around and rebolt it? I'll give that a shot now.
#13 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted February 09, 2014 - 06:57 PM
Your plate is right just goes in hole to right of the one you have it in. Is it your cylinder not working as stated or just not giving clearance you want?
#14 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted February 09, 2014 - 07:33 PM
It's not giving me any clearance up or down. The cylinder is going in & out. Ill try to take a video tomorrow of it in action.
#15 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted February 09, 2014 - 08:15 PM
First things first your lift bar most have pin affixed to bar on lift plate end should be around 24& 1/2 inches long. You say not ether way I'm wondering if if your pivot pin is seized up. When you have lift bar disconnected can you move blade up and down by hand>
