Clutch Ques #2
2 replies to this topic
#1 nelentaxidermy OFFLINE
nelentaxidermy
  • 8 Thanks
  • 11 posts
Posted February 05, 2014 - 06:31 PM
Ok we were test fitting and looking at making a clutch pedal extension.
We figured the length of a spacer using wood before I try using my welding skills.
But what we noticed is that my 7yr old, 52 pounds soaking wet still cant push the clutch in easily.
It currently has a red clutch spring installeed.
Any helpul hints, ad on's.
Pictures of a kid riendly set up.
Once we figure this out he is ready to tear up the track.
Thanks Pat and Stephen
#2 Chris11 OFFLINE
Chris11
    old Member
  • 1,672 Thanks
  • 971 posts
Posted February 05, 2014 - 08:54 PM
Make the arm longer, then the pedal pad longer
  • nelentaxidermy said thank you
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted February 05, 2014 - 10:45 PM
Chris has the right idea. What you can do is make your clutch arm longer, either make your own piece or buy one already made. Then you can add and extension to the pedal pad to make it longer and should be easier to push.
  • Chris11 and nelentaxidermy have said thanks
