Cub Cadet Original, New Project
6 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted February 03, 2014 - 11:04 PM
Well I just got another project. I traded my brother some stuff of mine for his Cub Cadet Original he got not to long ago. The tractor is rough and rusty from sitting under a tarp for 10 years but there is still enough left to work with. The spindles are rusted solid and the steering box is broken but I can fix them. First thing I will do is get the engine running so I can make sure the drive line is still good. After that I will pull the K161 out and replace it with a 18hp Briggs twin. I will fix the steering by replacing the whole front axel with one from a wide frame and I will also use a steering colum from a CC129 to replace the broken one. Next I want to have a rear lift so I will use the one I have that came off the same 129 the steering parts are coming from. When I parted out the 129 I saved the rear frame rails so I will shorten them down and bolt them on the trans so I can mount the rear lift. To make the rear lift work I plan to use a hydraulic lift system from I JD 112 that I have. I want to build the rear lift this way so that I can finally use my Gannon Eartcavator that I have had for over a year now.
  • hamman, twostep, Jlaws and 2 others have said thanks
#2 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted February 04, 2014 - 12:11 AM
Sounds like a great project, should be a real work horse when done
  • farmerall said thank you
#3 83MALIBU OFFLINE
83MALIBU
  • 40 Thanks
  • 69 posts
Posted February 04, 2014 - 07:00 AM
Sounds like you have things planned out. Should be an interesting project.
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted February 04, 2014 - 07:14 AM
Interesting project, that will be a real workhorse when you have it done.
#5 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted February 04, 2014 - 12:31 PM
Farmerall , what model 18 hp Briggs twin are you going to use ?
When I did my Cub Original twin cylinder conversion I kicked around the ideal of using a 18 hp Briggs opposed twin engine I had sitting around the garage , but quickly learned that it was to tall and wouldn't clear the hood when closed without cutting it .  I could have used spacers and raised the console and front grill but instead I settled on a Kohler Magnum twin because it wasn't quite as tall and it barely clear the hood when closed .
Half the fun I had was sitting on a 5 gallon bucket with a pen and note pad along with a tape measure , and doing a lot of measuring and figuring problems out ....
It sounds like a fun project , I'll be interested in how it turns out .
Edited by Jlaws, February 04, 2014 - 12:32 PM.
  • farmerall and twostep have said thanks
#6 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted February 04, 2014 - 02:18 PM
I will be using an opposed twin. When I get to swapping the engine I may just leave the hood off.
#7 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted February 04, 2014 - 06:11 PM
The great thing about using an Original is the fact that its belt driven and the bottom driveshaft has some adjustment for belt tension , so crankshaft height isn't a problem . Simply using a slightly longer or shorter belt depending on engine crank height .
Plus the engine mounts on a flat plate so re-drilling a different set of engine mounting holes is easy .
The rearend is pretty bullet proof and will have no problem handling 18 hp .
The down side is the belt may have problems handling 18 hp and your clutch may need a heavier spring . I ended up putting a double pulley on the driveshaft and engine for a matched set of drive belts and used a pulling clutch spring .
I reinforced the frame with gussets because they are prone to crack at the reduction housing mounting area with just a stock engine .
But then again I use mine as a plowing tractor and under normal use I could have probably gotten by without all the additional mods .
I'm just letting you know some of the issues you may run into with the bigger engine .
Edited by Jlaws, February 04, 2014 - 06:41 PM.
