Building Loader For My 1650 Cub
what hyd pump do i need
12 replies to this topic
#1 dadscub OFFLINE
dadscub
  • 14 Thanks
  • 14 posts
Posted February 03, 2014 - 08:03 PM
Ok im gonna build a loader for my 1650 and not real knowledgeable on hyd pumps as far as gpm, press, and so on! im a farmer so you would think i would know this stuff but nope. so any help would be appreciated!!!!!!!!  when im done with this badboy ill post some pics ive  painted cars for the last 30 years so ya it looks pretty cool!!! small version of my dads pride and joy 1466 IH. he talked about doing this for years to his cub!!  ( which is the one im doin now)  he passed 2 years ago so its a pretty important build! oops sorry bout all the babble!!!
  • olcowhand, hamman, boyscout862 and 1 other said thanks
#2 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted February 03, 2014 - 08:13 PM
6 to 8 gpm is plenty.  If you have too much volume, then the loader will react too fast.  But if using pulley & belt to drive the pump, the ratio can be changed if needed.  Pressure can depend on cylinder bores.  I have 2" lift cylinders, and I'm only running around 800 to 900psi (pressure relief setting) and it will lift more than is safe.  If running smaller cylinders, it will take more pressure to raise the same load.  1500psi is well beyond what you would need.
  • hamman, EconChuck and dadscub have said thanks
#3 dadscub OFFLINE
dadscub
  • 14 Thanks
  • 14 posts
Posted February 03, 2014 - 08:21 PM
i see alot on ebay but with the press and gpm ur talkin bout. any other options i should be lookin for in description? ur pry thinkin holy cow this guy is lost!!!
  • hamman said thank you
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted February 03, 2014 - 08:22 PM
Good luck and post pics as u go. Tom
  • hamman and dadscub have said thanks
#5 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted February 03, 2014 - 08:28 PM
THIS pump is basically identical to the pump I am using on my Massey 1655 with FEL.  Mine is off a Case 446, and I am running belt to drive it.  Some pumps can't handle side loads on the shafts, but mine is holding up well after quite a few years of heavy use.  I am running a 5/8 belt, so I don't have to have it real tight, so it doesn't load the shaft as much.
  • Alc and dadscub have said thanks
#6 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted February 03, 2014 - 08:29 PM
Also, when you look for a spool valve, be sure it has an adjustable relief valve built in.
  • dadscub said thank you
#7 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted February 04, 2014 - 06:43 AM
Sounds like a nice project and I'm lookoing forward to seeing it. And it might be nice to get a valve with a float position on one spool.
#8 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted February 04, 2014 - 07:17 AM
That will be a fun project. You will learn a lot about hydraulics when you have it finished.
#9 Cvans ONLINE
  • 6,467 Thanks
  • 6,058 posts
Posted February 04, 2014 - 11:51 AM
From experience I have found that having a pump larger than needed is not a good thing. The more oil you flow the more heat you generate and heat is not a hydraulic systems friend. You can however control the flow by changing the rpm of the pump. Rule of thumb provided by a hydraulics vendor, pump flow per minute should not exceed reservoir capacity.
 Good luck with your project.
  • KennyP and dadscub have said thanks
#10 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted February 04, 2014 - 12:13 PM
Great point!  I have a pump with a max flow of 10 or so gpm, BUT, I have it reduced with pulleys about 3 to 2, then I usually only run a bit over 2200rpm.  So likely I'm not pushing 3 to 4gpm if that much.
  • Alc, KennyP, Cvans and 1 other said thanks
#11 dadscub OFFLINE
dadscub
  • 14 Thanks
  • 14 posts
Posted February 04, 2014 - 03:12 PM
Holy cow this site is the bomb!!!  never heard of so many people with so much awesome advice ive learned more in two days talkin to you guys its been great now i feel like im gettin somewhere! and yes ill get my pics in order on project dads old cub as soon as my daughter gets back from college for a weekend to show me how ha ha
  • olcowhand, Alc, KennyP and 1 other said thanks
#12 KennyP ONLINE
  • 37,506 Thanks
  • 45,509 posts
Posted February 05, 2014 - 05:22 AM
:wave: Welcome! Glad you like it here. Look at the link at the bottom of this post for pic help. Great video on uploading pics.
  • JoeMopar and dadscub have said thanks
#13 shorty ONLINE
shorty
  • 5,287 Thanks
  • 5,169 posts
Posted February 05, 2014 - 05:59 AM
Welcome to the forums!
Sounds like you have a neat project full of memories.
