Lombardini Diesel For Repower Part 3
14 replies to this topic
#1 VICHARRIS OFFLINE
VICHARRIS
  • 102 Thanks
  • 56 posts
Posted February 02, 2014 - 04:34 PM
I finally have finished installing the Lambardini 25LD330/2 diesel engine into the JD 316 tractor. Re-routing the the air filter assemby, to the front of the engine. Fabricated a exhaust manifold to mount the new horizontal muffler. The air intake and the exhaust were mainly constructed, using black threaded pipe, screwed or welded. The electrical wiring has all been sorted out. Now what is left is fixing the engine cowling and installing Sylvannia H4351 2inch height headlight assemblies. The last bit of work will wait, to the milder spring weather.
  • olcowhand, gopher, sacsr and 5 others have said thanks
#2 boyscout862 OFFLINE
  • 13,440 Thanks
  • 9,385 posts
Posted February 02, 2014 - 04:55 PM
WOW, what a nice job! I bet you can't wait until spring to take it for a test drive. Good Luck, Rick
  • VICHARRIS said thank you
#3 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted February 02, 2014 - 04:59 PM
Nice clean install!
#4 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Looks great! Did you have any trouble hooking up to the drive shaft?
  • VICHARRIS and Trav1s have said thanks
#5 Arti OFFLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted February 02, 2014 - 06:35 PM
Looks like it belongs in there. Nice job.
#6 olcowhand OFFLINE
  • 42,400 Thanks
  • 31,803 posts
Posted February 02, 2014 - 06:37 PM
Yes, a very clean/stately conversion.  Looks like factory!.........but much better!  :thumbs:
  • 14,863 Thanks
  • 15,511 posts
Posted February 02, 2014 - 10:31 PM
Very nice job!! Is the engine soldi or iso mounted? I noticed the air filter is solid mounted, that's why I'm asking. The Yammars really flop around when starting a shutting off.
  • VICHARRIS and boyscout862 have said thanks
#8 Cvans ONLINE
  • 7,077 Thanks
  • 6,294 posts
Posted February 03, 2014 - 02:07 PM
Sure looks nice from the photos. Hope you get a lot of good use out of it.
#9 VICHARRIS OFFLINE
VICHARRIS
  • 102 Thanks
  • 56 posts
Posted February 04, 2014 - 09:12 PM
The engine is almost basically solid mounted. The Lombardini engine mounts rest on 1/8 inch Loctite rubber -cork material. When you rev the engine up, the frame has a certain amount torison flex.
The drive shaft , started out with the original lenght, shorten to accomondate the engine position. A short (Onan) stub drive shaft and a SKF universal joint installed along with an adapter plate was used at the engine end.
Maybe next year, I will look into power steering.
This year, I will start to paint different parts of the tractor. Replace neccessary parts to get the mule drive and 48 inch mower deck operational.
Later on this year,..start to build a Cat 0 3-point hitch. So the green tractor maybe oneday. Can field forough plow and rotortill beside the MF 1650. A dual team in motion.
  • KennyP, sacsr and Cvans have said thanks
#10 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted February 19, 2014 - 06:55 AM
If I may ask, where did you come across that engine and how much did you pay for it? I am after a similar one to replace my ailing Kohler in my 1969 JD 140.
Sent from my ASUS Transformer Pad TF300T using Tapatalk
#11 VICHARRIS OFFLINE
VICHARRIS
  • 102 Thanks
  • 56 posts
Posted February 21, 2014 - 07:07 PM
A couple years ago, an ad for sale was places in Kijji. For used diesel engines, off of military diesel powered hydraulic packs. There was about 20 engines to choose from. All of them being 24 volt setups, except for two engines. I bought the only two of 12 volt engine set-ups. The price was resonable for running diesel engines. $700.00 for the pair. One of them is now running in the JD 316. The other will be powering my second 1650 MF garden tractor, The Massey has taken a year or two longer to finish, because of not being sure how I wanted the drive line assembly to be. The number of run hours on these engines is not known. But with 20 degree F. outside temperature, and with winter grade diesel fuel. 20-30 seconds of glow plug juice, they light up just fine.
  • coldone, sacsr, boyscout862 and 2 others have said thanks
#12 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted February 23, 2014 - 07:04 AM
Thank you...
Sent from my CAT B15 smartphone.
#13 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted March 25, 2014 - 07:10 PM
BE AWARE Excessive cam wear can cause runaway i have a 3300 30hp with a worn out cam and it is uncontrolable after it starts and i don't have the 700.00 dollars for the cam and thats if it's still available /not including the injectors or the almost 100.00dolors for the oem shim kit to set the injectors up . your set up looks good and the engine looks newer than mine so you may never have a problem but just in case i would install a mechanical fuel shutoff to kill it if it should ever runaway good luck and remember, no good diesel goes unpunished :smilewink:
  • VICHARRIS, boyscout862 and twostep have said thanks
#14 VICHARRIS OFFLINE
VICHARRIS
  • 102 Thanks
  • 56 posts
Posted March 27, 2014 - 08:46 PM
Thanks for the warning. I have check both or my diesl engines. And they both have the factory electrical fuel shut offs, and a separate mechanical manual fuel shut off.
I personally like diesel engines. I service and maintain two VW diesel Jettas.
Thank-you
#15 Cvans ONLINE
  • 7,077 Thanks
  • 6,294 posts
Posted March 27, 2014 - 10:29 PM
A vehicle I've thought would be fun to own. My Son drove one for many miles and it survived his abuse.  :smilewink:
