Wanted
Governor Assembly
5 replies to this topic
#1 Traill95 ONLINE
Traill95
    Traill95
  • 1,804 Thanks
  • 991 posts
Posted February 01, 2014 - 07:21 PM
I am looking for the governor assembly for a wm or wmb Briggs and Stratton engine.  The pictures are of the assembly I need. I need 2 sets of complete linkage from carb to the vane included.
OOPS forgot to mark as wanted. :wallbanging:
Edited by Traill95, February 01, 2014 - 07:35 PM.
#2 Traill95 ONLINE
Traill95
    Traill95
  • 1,804 Thanks
  • 991 posts
Posted February 01, 2014 - 07:36 PM
Went back and edited.. One of these days I will learn to look before I leap. :smilewink:
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,680 Thanks
  • 1,349 posts
Posted February 01, 2014 - 07:48 PM
I may have one. I'll look the next time I'm outside.
  • Traill95 said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted February 01, 2014 - 07:54 PM
Looks to be the same setup used on all cast iron small block Briggs, N series, 6 and 8, even the 5.
99278 Air Vane
62893 Linkage
I don't have either one.  If Nate doesn't have one, I can get my Briggs supplier's arms twisted and see what they can do for you.
Ben W.
  • trowel and Traill95 have said thanks
#5 trowel OFFLINE
trowel
    Summer.
  • 4,821 Thanks
  • 4,533 posts
Posted February 01, 2014 - 08:43 PM
99278 Air Vane
62893 Linkage
Ben W.
Yep, models N, 5, 6, and 8.
  • superaben said thank you
#6 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,680 Thanks
  • 1,349 posts
Posted February 02, 2014 - 12:03 AM
OK here's what I got. The first pic is a WMB and the second is a N. They're two different setups and the air vane would not be interchangeable between the two because the height of the vane will not clear the shrould. The linkage rod is also shorter on the N. I don't have all the part numbers for them but the way it looks to me the N, 6, and 8 would be the same and a 5 should be the same as a WMB (assuming the carb set up is the same).
If the linkage and air vane off the WMB is something your interested in send me a pm.
