Hyd. Filter For 1010 Meteor
4 replies to this topic
#1 Danny McCloskey OFFLINE
Danny McCloskey
  • 49 Thanks
  • 28 posts
Posted February 01, 2014 - 05:15 PM
Does anyone know the number of the hydrostatic filter that is mounted on the firewall of the 1010 Meteor?  One of mine acts very weak when driving it, the other one responds quicker.  I took the number that is on the cover to my local NAPA, and they couldn't cross it over to anything they have.
Thanks
Danny McCloskey
#2 boyscout862 ONLINE
  • 13,546 Thanks
  • 9,427 posts
Posted February 01, 2014 - 05:33 PM
Welcome to GTT. Relax and enjoy the site. Someone will be along with your information. Check our manuals section too. 3 free downloads per day. Good Luck, Rick
#3 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted February 01, 2014 - 06:28 PM
Hydrostat filter is Napa 1487 or Fram C1678
Apparently its a very old number that hasn't been used in anything for quite some time.  My local Napa showed only one in stock at their warehouse and it was old packaging and covered with a very thick layer of dust.
It wouldn't hurt to change the fluid and filter but I doubt that's the cause of your trouble as the filter is in the reservoir.  I would look closely at the hydrostat belt tension.  Someone else recently mentioned sluggish performance and thought he had no belt slippage.  When he pushed on the belt while it was running he reported the tractor took off.
Edited by Canawler, February 01, 2014 - 06:33 PM.
  • sacsr said thank you
#4 Danny McCloskey OFFLINE
Danny McCloskey
  • 49 Thanks
  • 28 posts
Posted February 03, 2014 - 06:52 PM
Thanks for the information.  I thought it might help to change the filter and fluid.  The belt is new, with a strong spring on it.
Danny
#5 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted February 03, 2014 - 10:24 PM
I always forget to mention this one but make sure to fully close the bypass valve that allows the tractor to be pushed. If that's open a crack you would probably get the symptom you mentioned.
