Ariens Yt 130G
4 replies to this topic
#1 thetipler OFFLINE
thetipler
  • 1 posts
Posted January 31, 2014 - 07:27 PM
I just bought a 1990'S Ariens YT130G riding lawnmower with a YT 36" snowblower attachment.
The auger/drive belt needs to be replaced. I have never worked on a snowblower before.
How do you change the belt?
#2 HDWildBill OFFLINE
  • 8,985 Thanks
Posted January 31, 2014 - 07:31 PM
Welcome to GTtalk.  Since we don't get a lot of snow here in the south I'll defer your question to someone more knowledgeable about snow-blowers.
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,453 Thanks
  • 10,181 posts
Posted January 31, 2014 - 09:06 PM
Since I can't find a pic of one onlline, and Ariens parts lookup doesn't recognize that model #, we'll just shoot from the hip. The belt runs from the bottom of the engine, on a pulley, to a pulley on the snowblower. There is one or two or three pulleys along the way. One of those will move. Either by a lever, or a spring, or both. Pulling, pushing, or moving that will allow you to get the belt off that pulley. Then you can remove the belt from around the other pulleys and remove it. Compare the belt to the new one you purchase to make sure it's the same size, then put the new belt in the reverse order of how the old one came off.
I may be able to get more precise if you have model #'s off your tags on the mower and the snowblower.
#4 shorty ONLINE
shorty
  • 5,919 Thanks
  • 5,452 posts
Posted February 01, 2014 - 06:25 AM
Welcome to the forums!
I don't know to much about the blowers myself. If you can get the model number off the blower or tractor, we could pull up a diagram of the belt configuration.
#5 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted February 01, 2014 - 01:53 PM
Not a good copy .Hard to get a good scan,it is a thick book.It has a parts list for an Ariens Sno-Thro.935 series Yard Tractor Repair Manual
Blower repair manual
Attached File  ariensst.PDF   3.94MB   53 downloads
