Vanguard 14.5 Hp Engine Questions
8 replies to this topic
#1 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted January 31, 2014 - 05:49 PM
I got this engine for my Sears GT16 project but have a question about the wires coming from the engine.  The red one is the ignition that I figured out.  There's a blue wire that has a connector to a black wire that goes to the carburatorbowl, what is that wire for?
#2 JDBrian OFFLINE
  • 9,601 Thanks
Posted January 31, 2014 - 05:55 PM
Have you had a look on the Briggs site to see if they have a manual for that engine. There may be a fuel solenoid on the carb that is activated by the extra wire but I've never seen one of those engines so it's just a guess.
#3 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted January 31, 2014 - 06:06 PM
So, it's a solenoid screwed in the bottom of the carburator?  What is it suppose to do?
Edited by woopud, January 31, 2014 - 06:06 PM.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted January 31, 2014 - 06:19 PM
Prevent backfiring on shutdown by shutting off fuel flow.
#5 EricFromPa ONLINE
EricFromPa
  • 3,513 Thanks
  • 3,065 posts
Posted January 31, 2014 - 07:25 PM
They're a pain in the BUTT.Those Solenoids only last for a few years before they burn up.They basically Stop fuel flow through the main jet once the engine is off.
They get power and open up when the Key is turned to the Start and Run positions.If they go bad or get no power the engine will not start.There's a simple way to render them useless that I am more than happy to share with you.PM me with a Pic of your Solenoid if you want to permanently disable the little troublesome bugger.
Warning this is considered a Safety feature on these engines (just like a neutral safety switch and or Brake safety switch) is only to be disabled at ones own risk. :rolling:
  • Cat385B, superaben and Sawdust have said thanks
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 31, 2014 - 09:37 PM
:bigrofl: I wish.
BANG !
#7 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted January 31, 2014 - 09:46 PM
:bigrofl: I wish.
BANG !
I didn't meant to imply that is what they do, just that it is what they are intended to do.
  • trowel said thank you
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 31, 2014 - 09:52 PM
Eh, no harm done, just had a moment, not making fun of your post, just the solenid, hate those things.
You are right, regretablly they wear out very quickly and then,.......the god forsaken BANG !!!
#9 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted March 24, 2014 - 06:39 PM
Still trying to figure out the wiring, I only need the red wire for the ignition right?  How do I disable the solenoid?
