Problem With The L/60
3 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,147 Thanks
  • 2,640 posts
Posted January 30, 2014 - 12:47 PM
Had a little problem yesterday!  It's been cold lately & I had started any tractors for a while, wanted the 70 I to go to the back shed & get the #10 cart to bring some wood to the shop.  70 I wouldn't start right off, so I tried the L/60.  It started, so while the 70 was on the battery charger, I headed to the back.  Got almost to the back shed, it spit & died!  I suspect the head gasket blew, so I pushed into the shed & covered it for now.  Won't be able to do anything with it for a while since I can't use my right arm, I'll get to it eventually!
Went back & got the Gator to bring the art load of wood up, 70 I started later, so I drove it around the yard a while to burn out any excess gas.  ~~  Lowell
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,309 Thanks
  • 4,948 posts
Posted January 30, 2014 - 02:25 PM
Sounds like job security  :wallbanging:
Seems any time a fellow has several engines one or two want to have some sort of fit.
Hope it's a simple fix.
Don't be moving firewood with that arm!  :brain_fart:
  • grnspot110 said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted January 30, 2014 - 02:40 PM
bad news, Lowell - but anyhow, you've great tractors. and when spring comes, everything is getting better!
#4 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted January 30, 2014 - 03:31 PM
Gives you something to do when the arm heals!
