Case 646 & Kubota Z482
84 replies to this topic
#61 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted April 16, 2014 - 05:09 AM
Good to know skyrydr2. Instead of messing with the mechanical pump I will just install the electric one. Looking at the Kubota garden tractor parts diagrams, they all use an electric pump with the tank mounted under the seat. The mechanical pumps only seem to be used in the tractor models with the fuel tank mounted above the engine. I am not going to second guess the OEM design on the fuel system! My D722 has the pump block off plate, so I will just swap the pump and plate between the engines.
#62 MH81 OFFLINE
  • 29,978 Thanks
Posted April 16, 2014 - 06:28 AM
Had a chance to catch up in this thread. Great repower and I hope you get your fuel issues straightened out.
#63 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted April 27, 2014 - 07:59 AM
Yesterday I finally got to work on the Case again. Got it all wired, got the muffler installed, and mounted and hooked up the electric fuel pump. Had it running on its own for a few minutes and everything works as it should. I have one small fuel leak at a splice in the line to fix, and still have to hook up the throttle and shut down cables and find space for the air cleaner.
#64 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted April 27, 2014 - 09:53 AM
I hope we will get to see a video of it running soon. Sounds like a great build.
#65 Cvans ONLINE
  • 7,289 Thanks
  • 6,377 posts
Posted April 27, 2014 - 06:20 PM
:wewantpics:  :camera:
#66 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted April 28, 2014 - 05:26 AM
Had to work on a different project yesterday, but I did start the Case a couple of times to "test" how it starts (aka, I wanted to hear it run!) and it fires right up easy. I can only fit a lawn and garden battery in it, so 300 cca is all I have but it seems to be enough. I don't really plan to see much use for it in the winter, but it will be parked inside year round. Still looking at block heaters and will probably install one by winter.
I wanted to use a small round canister air filter for the engine (from a Kubota RTV) but there just is not enough room for it under the hood, and with the loader it can't hang out the side. Think I am going to try to make an air cleaner from a Kohler K series work.
I will get pictures soon, but other than the muffler and some wires running around it doesn't look much different. And a video will be posted once I can get it out of the shop and run it around some.
  • Cvans said thank you
#67 Cvans ONLINE
  • 7,289 Thanks
  • 6,377 posts
Posted April 28, 2014 - 10:14 AM
Seems like the air filters and batteries are always the hardest things to find a place for. I try to keep the intake for the air filter in front of the radiator or out of the engine compartment.
#68 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted May 02, 2014 - 02:12 PM
Here are some current pics.  I think I figured out the air filter this morning using a bunch of 1.25" PVC elbows.  Hoping to seal up the fuel leaks this Sunday and take it out of the shop for a test run.  Still have to make a couple of wire swivels to hook up the throttle and fuel shut off cables.  Really close now.
DSC03311.JPG DSC03312.JPG DSC03314.JPG DSC03315.JPG DSC03316.JPG DSC03317.JPG DSC03320.JPG DSC03323.JPG
  • olcowhand, Alc, Texas Deere and Horse and 1 other said thanks
#69 bowtiebutler956 OFFLINE
bowtiebutler956
  • 669 Thanks
  • 796 posts
Posted May 02, 2014 - 08:57 PM
 Won't be long now! :dancingbanana:  It looks like your doing a great job of getting it sorted out, and I'm really looking forward to seeing it finished. :thumbs:
Matt
#70 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted May 04, 2014 - 08:32 AM
Here is a video of it running. Everything is finished. Of course it started to rain just as I was ready to take it out of the shop, so this afternoon I will get a video of it outside.
Edited by boss351c, May 04, 2014 - 08:42 AM.
  • olcowhand, coldone and Alc have said thanks
#71 bowtiebutler956 OFFLINE
bowtiebutler956
  • 669 Thanks
  • 796 posts
Posted May 04, 2014 - 09:27 AM
 That little Kubota purrs like a kitten! Look forward to your next video. :thumbs:
Matt
#72 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 04, 2014 - 10:43 AM
Slick!  I see it must still be cold up there, with that heater going.
#73 Cvans ONLINE
  • 7,289 Thanks
  • 6,377 posts
Posted May 04, 2014 - 04:13 PM
Thanks for the photos and video. Really enjoyed them.
Before I forget, looks like you used some plastic or nylon fittings in your upper radiator hose. Keep and eye on those after your engine comes up to operating temps. I haven't had very good luck with those as they tended to buckle under the hose clamps when they get hot. Started using long radius copper sweat fittings with good luck.
Your engine sure sounds nice and I didn't see a puff of smoke out of her. Should last you a long time. Your loader is really quick. Kind of wish mine was a little faster.
You do nice work.
#74 boss351c OFFLINE
boss351c
  • 84 Thanks
  • 60 posts
Posted May 05, 2014 - 05:16 AM
Thanks guys. It is still in the high 30's a lot of mornings here, so the heater is needed.
Cvans- those plastic elbows are the one thing I don't like out of the whole engine swap. I plan to change to something in metal soon.
No new video, didn't have anyone to run the camera. I did run it a couple times outside for about 15 minutes each time. Temp runs right at a constant 170 degrees. This diesel has more power at a fast idle than the Onan had wide open - feels more like 20hp than 13hp! Very happy with the swap and I would do it again in a heartbeat. Now I wish it would dry up around here so I can start working it for real. I may have to start on building the three point hitch for it until then.
  • olcowhand said thank you
#75 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted May 05, 2014 - 05:27 AM
That looks and sounds great. Waitin for a work out vid.
