Chain Advice
5 replies to this topic
#1 MH81 OFFLINE
Posted January 02, 2011 - 10:12 PM
I did a little Wheelin'/Dealin' for a couple of sets of tire chains. One set is too short & one set is too long. The too short ones are a project for another day (They're bull chains) but the too long ones are going on the Sears 7.
The ones that are too long are giving me fits in the following way: If I cut them where they need cut, I will loose a cross bar. I am able to take it off & relocate it, but it'll be 2 links instead of 3 in between the cross bars there. If I connect it at the cross bar, the chain has one link's worth of slop, but I can take that up with cross springs.
Which way would you guys go?
Edited by MH81, January 02, 2011 - 10:28 PM.
#2 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted January 02, 2011 - 11:17 PM
I would go with one link's worth of slop and use the cross springs.
#3 mjodrey OFFLINE
Posted January 03, 2011 - 05:38 AM
Yes,I would also do this.
#4 grand OFFLINE
grand
  • 2,042 Thanks
  • 2,014 posts
Posted January 03, 2011 - 08:24 AM
I'm no expert but I would agree with the previous posts. The chains that came with my 600 are a little big I always thought but seem to work well. You will have the cross link go under the tire perhaps a little loose, but it will be there for the traction you want. Just my thoughts.
#5 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted January 03, 2011 - 10:28 AM
You can do it the Homemade way also :D
I cut old tire tubes and use "S" hooks . Works great and lasts longer than bungee cords do.
#6 MH81 OFFLINE
Posted January 03, 2011 - 08:34 PM
Guys I appreciate it. It's what I was hoping you'd say also :D less work.
I put the results under "To your Tractor" Chain Tighteners
Edited by MH81, January 14, 2011 - 11:01 PM.
