What Size Carb To What Size Kohler?
6 replies to this topic
#1 dodge trucker OFFLINE
dodge trucker
  • 2,436 Thanks
  • 3,126 posts
Posted January 28, 2014 - 10:29 PM
is there any rhyme or reason to what size carb was used on the K series?   Everything I see says the 12 HPs (K or M series) has #26s but I have 2, M12's here with #30 carbs.  I don't think they have been changed out either, judging by the paint on them I am thinking these carbs are original to the engines...
What determined what size carb was used with a given engine, and why would 2 of same model series (say  K 301 for example) have 2 different sized carbs?
#2 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted January 28, 2014 - 11:28 PM
My reading leads me to believe the following:
26 = k241/k301
28 = k301  (if you can find one)
30 = k321/k341
I have heard of 30s being used on the k301 but have no experience with them.  I know my k301 runs great with the 26 installed on it. I would rather chance a 30 than fight another walbro (and my 312 has a Walbro on it :wallbanging: )
#3 Alc OFFLINE
  • 6,886 Thanks
  • 7,461 posts
Posted January 29, 2014 - 06:45 AM
Where do you find the carb size ? Do the sizes mean anything as far as say #30 has a throttle bore of 30mm ? If it's not hard to find I will try to see what's on my 2 12hp Kohlers on the PKs
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 29, 2014 - 09:10 AM
Venturi bore, and yes in MM.
Usually casted on the mouth of the carb or for Carter looking inside the carb (choke side) on the venturi.
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 01, 2014 - 12:22 PM
I am running a #26 on a K321. No problems with lean running.
#6 dodge trucker OFFLINE
dodge trucker
  • 2,436 Thanks
  • 3,126 posts
Posted February 02, 2014 - 07:59 PM
ok then.... next question.  I know there is some adjustability due to the mixture screws... but the actual jetting isn't changeable within the carb. While trying a carb from a K91 on my 301s would be stupid/crazy, I have a pair of the M 12 version of the 12 HP)  with "30" carbs and seem to run just fine without seeming to be too rich. . Levi says in the post above this one he has a #26 on a 321....smaller carb than me, on a bigger engine. Mine being electronic ignition with no timing adjustment,  and his being a point ignition with timing variable based on point gap /and wear-condition/ making a difefrence in carb requirements?
Are the main jets and such the same, on "all" carbs of a given size no matter the HP rating of the engine it is put onto?
meaning (in my case) my #30s are jetted the same as ones that would come on a K341 (16HP)?
I do understand that application itself dictates not only  mixture settings but jetting too.
so on a constant, high load application they put a carb with a different size venturi  in order to (also) increase jetted size?
why else would we have kohler putting larger carbs on some engines of the same HP than others?
I wonder with all else being equal ,if there is much of an actual  HP difference between engines of the same displacement but a different sized carb? same exhaust, same load, same overall condition, etc?
Briggs in particular seems to be able to greatly vary the HP of a model line just by applying a different carb especially on the older L heads.. 10 HP 11 HP 12 HP 12.5 HP  all being the same displacement but different power ratings.... though stickers are cheap to print and stick onto engines off the same assembly line...
#7 WpgJetFan OFFLINE
WpgJetFan
  • 18 Thanks
  • 35 posts
Posted April 17, 2014 - 01:44 PM
http://gardentractor...om/carbfuel.htm
All of the Kohler carb info you need is here
