Cub Cadet/ Kohler Compression Release Issues ?
15 replies to this topic
#1 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 28, 2014 - 09:05 PM
I have been told there is a tab on the camshaft that breaks, requiring a total teardown. Is there a way to bypass this with a manual compression release ?
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,676 Thanks
  • 5,052 posts
Posted January 28, 2014 - 09:42 PM
you could drill the head, tap the hole, and install a brass 1/4 turn petcock
I recommend fixing it right
I have a pull start Gravely L that has the homemade compression release mentioned above. I bought it that way.
Edited by Gtractor, January 28, 2014 - 09:46 PM.
  • Cat385B said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,289 Thanks
  • 10,116 posts
Posted January 28, 2014 - 09:44 PM
Amurphy, is this a Cub Cadet 127 with the Kohler K301?
#4 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 28, 2014 - 09:55 PM
Its an older 12 horse K engine.In a 65 105 but obviously out of a 125 or something with the 12 horse. I bought it rebuilt by I dont know who. It ran and started fine for a while, 3months, and now it wont turnover on compression. I took the side cover off and the spring is not broken but rather , just off. I have been told there is a tab broken on the end of the camshaft.
#5 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 28, 2014 - 09:58 PM
I hate to have to tear it completely down and rebuild on a fresh rebuild over this. Its the last part if it is on the cam. A ported head would get me thru til another rebuild. Whats the disadvantages. The head can be replaced later easily.
  • Gtractor said thank you
#6 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 28, 2014 - 10:01 PM
Dont know about the 301 number. Its an old cast Iron K engine , is what Im told. I could look at the numbers on it again if need be but I thought they were pretty common the same in cast iron kohler back in the cub days. The mower is a 65
#7 Texas Deere and Horse ONLINE
  • 14,866 Thanks
  • 15,512 posts
Posted January 28, 2014 - 10:23 PM
The 12 HP Kohler is a model K-301, that's what CAT was trying to tell you.
  • Cat385B and Amurphy have said thanks
#8 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 28, 2014 - 10:50 PM
Im new on here and computer illiterate, lol   Cant figure out how to carry on a thread. thanks for bearing with me
#9 Texas Deere and Horse ONLINE
  • 14,866 Thanks
  • 15,512 posts
Posted January 28, 2014 - 11:52 PM
If it were my engine, I would tear it down to make sure nothing else is messed up. If a piece of the Compression release broke off, it can get into the gear train and really cause some damage to the whole engine.
  • olcowhand, boyscout862, New.Canadian.DB.Owner and 2 others have said thanks
#10 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 29, 2014 - 12:26 AM
Most definitely get in there and fix it correctly.
If it's broke that piece can cause big problems internally.
  • Texas Deere and Horse and boyscout862 have said thanks
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 29, 2014 - 06:24 AM
I agree. Those engines are a real workhorse and will last for a long time if properly rebuilt. They are well worth the time to pull it apart and do the repair. Get yourself a copy of the Kohler K series service manual from the Kohler site and have a look at the procedures for tearing the engine down and fixing this problem. That will let you know what you are up against. Hopefully nothing else is damaged and you are mostly looking at the labour to do the job.
#12 boyscout862 ONLINE
  • 13,450 Thanks
  • 9,394 posts
Posted January 29, 2014 - 07:11 AM
Welcome to GTT. Relax and enjoy the site. Good Luck, Rick
#13 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 29, 2014 - 08:53 AM
Your not the only one, computers are an animal of there own.
Yes, thoses K-series last, would take the time to do it right, quick fixes can lead to more problems.
  • Amurphy said thank you
#14 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 29, 2014 - 07:01 PM
So it came unhooked? If it did, it might just be a simple matter of rehooking the spring on the flyweight.
Edit: Unless somebody's been in the engine already, bending the tab around and making it weaker, it would take a lot to snap it off.
Edited by LTD, January 29, 2014 - 07:04 PM.
#15 Amurphy OFFLINE
Amurphy
  • 4 Thanks
  • 8 posts
Posted January 30, 2014 - 10:15 PM
I was told they bend the tabs after they are worn and then they break.  If the spring is off, there's a reason....? Do the spring ends just hook over the steel plate at where they reach. I cant tell where they should hook.  I'd hook them up and try it.
