Rubber tire chain report
15 replies to this topic
#1 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 02, 2011 - 08:05 PM
Well after using the 1050 with rubber tire chains a few times I have come to the conclusion that they do in fact work well. Do they work as good as regular chains? No, but they are a great alternative if you want to save your blacktop. I used them with the blower and blade with minimal slipping. I even had the differential off most of the time.
  • grand, mjodrey, tractormike and 8 others have said thanks
#2 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted January 03, 2011 - 05:45 AM
Well that's good to know Brian.
#3 daytime dave OFFLINE
  • 5488 Thanks
  • 6781 posts
Posted January 03, 2011 - 07:28 AM
Yes, that is good to know. How bad does the black top get beat up with just regular chains? I haven't had the chance to use my new set of chains more than once. No ill effects noticed yet.
#4 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 03, 2011 - 10:19 AM
If you spin you will scuff up the driveway a little with regular chains. The driveway I have is about 2 years old and I didnt want to take any chances LOL
#5 RailmanB110 OFFLINE
RailmanB110
  • 21 Thanks
  • 44 posts
Posted January 04, 2011 - 12:56 AM
Most pavement damage comes from spinning wheels, so less it stands to reason, less spinning means less damage. I used to use std car type chains, & while they worked ok, I always thought they could be better. The last batch I bought on ebay had twice as many latteral bars. With wheel weights & water (4 parts water/1 car antifreeze w/tubes), I hardly ever spin anymore . They are well worth the extra bucks if you want to save the pavement.
Joe
  • Bolens 1000 said thank you
#6 tractormike OFFLINE
tractormike
  • 179 Thanks
  • 1488 posts
Posted January 04, 2011 - 07:00 AM
Thanks for the report!
#7 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted January 04, 2011 - 09:19 AM
Thanks for the update Doc, glad to hear they're workin' out good. As for regular chains, I know the more weight you've got on the drive axle the more damage will be done when you do slip. The big worry is turning though, I drove the QT16 down the road once with the 33" tiller and chains on it, and you could see a few little marks from straight line driving at top speed but everywhere I made a turn dug up some pretty good spots on the pavement.
#8 SnowmanPA OFFLINE
SnowmanPA
  • 13 Thanks
  • 38 posts
Posted February 08, 2011 - 10:06 AM
I put a set of these rubber tire chains on this winter and I agree that they work very well. I have a QT-16 with a 48" blade and a modest hill on my driveway. I have wheel weights and 5-gallon pail of rocks on my hitch. With this setup I'm able to actually plow up to about 6"-8" of dry snow going UP my driveway. Any more than that and I' limited to plowing downhill, but that works great!
#9 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 08, 2011 - 10:22 AM
Yeah, they work better than I first anticipated
#10 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted October 14, 2014 - 06:23 AM
How have they held up, Doc?
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 14, 2014 - 02:52 PM
Still look new minus a few scratches here and there,
I can now sell/supply them for most of the common sizes! :thumbs:
#12 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted October 14, 2014 - 06:44 PM
Hard to believe they work that good on hard packed snow or ice,seems like they would just slip
#13 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 14, 2014 - 06:51 PM
They actually have more grip than chains in the snow due to them covering a larger surface area than a chain, I  was also pretty satisfied with the results when I tried plowing the garden with them.
As for ice, nothing can compete with it, only spikes in your tires will help you there!
  • Gtractor and MH81 have said thanks
#14 trowel OFFLINE
trowel
    Summer.
  • 4847 Thanks
  • 4535 posts
Posted October 14, 2014 - 06:56 PM
Like paddles on a sand buggie in some ways, i wonder what would happen if someone added studs to the rubber strips, worth a try ?
#15 Rathwell OFFLINE
Rathwell
  • 20 Thanks
  • 13 posts
Posted October 15, 2014 - 10:00 PM
Thanks for posting this review up. I was wondering how well they would work.
Sent from my GT-N7105 using Tapatalk
