Kwik Way Loader
kwik way loader
20 replies to this topic
#16 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted January 28, 2014 - 08:47 AM
If you check pressure, make sure gauge is on a 'T' in line and not just connected to output line, that will blow out the pump seals.
#17 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted January 28, 2014 - 09:55 AM
I have no more advice to add, the first steps have been covered... However I will say this:
:wewantpics:
#18 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted January 28, 2014 - 01:28 PM
Just thought of this , if the loader pump is seperate from the working rear lift and the tractor is outside, it could have gotten moisture in the hyd system and froze
#19 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted January 29, 2014 - 05:23 PM
:wewantpics:
:ditto: and   :welcometogttalk:         Thanks,Tom
Edited by TomLGT195, January 29, 2014 - 05:23 PM.
#20 patman OFFLINE
patman
  • 3 Thanks
  • 5 posts
Posted February 01, 2014 - 08:26 PM
Ok guys it's working. Pto connects to the pump and two bolts gulf the two shafts together instead of a key. Bolts had warn down to the point where the pto would spin ant the pump would turn slow and loose but not enough to do anything. Thanks for your help. I will post pics once I put the front end of the tractor back together
  • Alc and Cat385B have said thanks
#21 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted February 01, 2014 - 08:29 PM
Sounds like an fix that was easy to swallow. Hope it saves your back, and we're looking forward to the pictures.
