Kwik Way Loader
kwik way loader
20 replies to this topic
#1 patman OFFLINE
patman
  • 3 Thanks
  • 5 posts
Posted January 27, 2014 - 08:36 PM
just bought a yardman 998 tractor with a kwik way loader.  pto on tractor seems to be working but no power in the loader.  won't move. Can someone tell me how to test to see if its the pump or any other suggestions?  No leaks found and fluid level is good.
Thanks
Patman
  • VintageIronCollector said thank you
#2 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted January 27, 2014 - 08:42 PM
:wave: Welcome to the forum! Help should be along shortly!
#3 NUTNDUN OFFLINE
  • 10,354 Thanks
Posted January 27, 2014 - 08:55 PM
I would check and make sure the shaft is spinning on the pump. If it is then next thing I would do is a pressure test on the output side of the pump. Is there an oil filter on the loader?
  • boyscout862 and superaben have said thanks
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 27, 2014 - 08:57 PM
I'm not familiar with Kwik Way.  However, hydraulics are hydraulics no matter what.
Oil comes from the tank to the pump to the control valves to the cylinders which picks up the load.
Make sure the key that drives the pump isn't sheared.  I'm assuming there is one.
You can tee in a gauge onto a pressure line to see if you are getting pressure out of the pump.
Is there a filter on the tank line, "suction line", feeding the pump?  Could that be clogged?
If you take a line loose at a cylinder, does any oil come out?
Are your control valves 1 lever you control (pilot "joystick" style) or two levers you work back and forth (forklift style)
Ben W.
  • NUTNDUN and boyscout862 have said thanks
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 27, 2014 - 08:59 PM
If I'm thinking like you I must be not as dumb as I look.  :D
Ben W.
  • NUTNDUN, Texas Deere and Horse and boyscout862 have said thanks
#6 Talntedmrgreen ONLINE
  • 3,296 Thanks
  • 2,320 posts
Posted January 27, 2014 - 09:00 PM
Does it have a pump, or is it plumbed to the tractor's hydro?  Kwikway offered them both ways, sometimes, both ways for the same model tractor.  For example, on the Legacy's, you can tap into the Sunstrand, or to the pump provided with the loader.  Take a look at your lines and make sure they are hooked up one way or the other.  No telling what a PO may have detached.
#7 patman OFFLINE
patman
  • 3 Thanks
  • 5 posts
Posted January 27, 2014 - 09:13 PM
Thanks guys.  Don't see a filter on the lines. Front pto spins and the chain coupler spins connecting to the pump.  Where can I get something to test the pressure coming out of the pump.  Where can i find out what thepressure should be.
#8 patman OFFLINE
patman
  • 3 Thanks
  • 5 posts
Posted January 27, 2014 - 09:28 PM
will have to  pull the pump and check for a key.  Don't have enough room to get my hand in and check.
#9 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted January 27, 2014 - 09:47 PM
Not sure about Kwik-Way, but some I've worked with had a filter built into one of the upright tubes/braces near the bottom where the hose couples up. If it sat and was dirty could be plugged there.
#10 patman OFFLINE
patman
  • 3 Thanks
  • 5 posts
Posted January 27, 2014 - 09:52 PM
Don't see anything on the upright post either.  Will check it out when I pull the pump and look for the key.  Hope it's a simple fix as it is cold as heck her in Michigan. it would be nice to use the loader on the snow.  Has a 3 point and a grader blade on the back but can't do much with a dead loader dragging around on the front of the tractor.   I do appreciate all the help and will keep you guys updated.
#11 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted January 27, 2014 - 09:59 PM
The relief valve would of been set at 1500 psi from the factory. If you get a gauge to test the pressure, make sure you get one rated to handle at least 2200 psi, or the gauge will become the relief port.
The filter should be on the bottom of the loader upright support, in front of your legs, opposite of the one that has the loader control valves.
  • sacsr and boyscout862 have said thanks
#12 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,821 Thanks
  • 4,309 posts
Posted January 28, 2014 - 04:53 AM
:welcometogttalk:
#13 Alc ONLINE
  • 7,357 Thanks
  • 7,639 posts
Posted January 28, 2014 - 06:31 AM
Welcome to GTTalk ,   tuff question without being there , at least for me lol ,  I would try the easiest thing that you can check on that tractor without doing a lot of work if possible . Maybe follow the output line of the pump to make sure someone didn't install some type of spliter ( I used one to switch from my fel to backhoe on my Ford ) , it might be a different lift for your grader blade idk without seeing it
  • superaben said thank you
#14 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted January 28, 2014 - 06:37 AM
Welcome to GTT. Check the fluid level. Download this manual. http://gardentractor...-loader-manual/   and this manual  http://gardentractor...-loader-manual/  There is also a Yardman tractor manual in our Manuals Section. You are allowed 3 free downloads per day. Good Luck, Rick
Edited by boyscout862, January 28, 2014 - 06:42 AM.
  • TomLGT195 said thank you
#15 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted January 28, 2014 - 07:38 AM
Lots of good suggestions above. I'd also check the valve linkage and make sure the valve spools are being actuated.
