K Series Ignition
6 replies to this topic
#1 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted January 27, 2014 - 12:38 PM
Hello everyone I have a k321 with breakerless ignition. My question is if I can change it back to a breaker type ignition? I dont see the spot where the breaker point usually go.
#2 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 27, 2014 - 12:54 PM
Those engines aren't plentiful, but I had a Wheel Horse GT14 with that system many years ago.  No, not able to switch it back easily anyway.  Would require machining a perfect size hole for a push pin, the mounting screw holes/etc.    Did your spark die?
#3 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted January 27, 2014 - 01:19 PM
No mine hasent died but I was just wondering if it was possible. Thank you
#4 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted January 27, 2014 - 01:43 PM
Hi,
I have a couple of Economy PK's with the electronic ignition and have not checked them that close.
But people claim the pushrod hole is there,  just a "plug" was installed.
I know mine have all the mounting holes drilled and tapped.
I've also collected spare coil and pickup parts.
Chuck
#5 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted January 27, 2014 - 02:21 PM
Thank you I will check into this
#6 glgrumpy ONLINE
  • 8,815 Thanks
  • 8,014 posts
Posted January 27, 2014 - 05:32 PM
Yeah, like Chuck says, most have a plug in the holes that ARE there already. BUT, plug gets pushed out to INSIDE the block. Some fish it out with a magnet, some have had it roll out with oil change thru that drain. OR, sneak out thru the filler plug if one down low in pan. The think with plunger and points, maybe a cover if not on there (with gasket) should be able to mount a coil, wire to the points from it, then power to the coil and should be good. OH,yeah, have to have a condensor that mounts on coil too, think on neg side same as points?  The Pos side of coil can go to key switch or a toggle. MUST change the key switch to one for Batt Ignition. Changes the M term from Magneto to the I term for Ignition. With Batt ign. you are turning OFF the power to coil, with a Mag Ign. you are just grounding the wire from Mag to stop engine.
#7 dodge trucker ONLINE
dodge trucker
  • 2,815 Thanks
  • 3,451 posts
Posted January 28, 2014 - 10:01 PM
oh, I thought the post was about a magnum  none of those have points....
