Mf620 Snowthrower....not My Favorite
3 replies to this topic
#1 JDGREEN140 OFFLINE
JDGREEN140
  • 38 Thanks
  • 43 posts
Posted January 27, 2014 - 08:01 AM
Well I have had my MF620 Snowthrower attatchment hooked up to my MF10 this whole winter and we had about 3 inches of snow this morning so I thought I could go out and give it a try for the first time. Everyone told me the owner that had this before me had always had snowblowed his driveway with this machine and it always worked great, he did his driveway for 40 plus years with this machine so I am assuming it always worked well. Well, its not working well for me. The most i can get the snow to throw it 5 feet tops. i have adjusted the tension on the belt via the MF620 manual, have everything well greased and chain oiled. I have even replaced the belt with the new one. I always spray the chute and auger with silicone spray so that the snow easily flows. I am running the tractor in 2nd gear variable speed 1-2 and I cant seem to win with this thing. Anybody else have an issues? I am also of course running the tractor at full throttle during pto operation. I really would like a snow blade but havn't been able to find one.
  • hamman said thank you
#2 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 27, 2014 - 08:05 AM
I am wondering if you have a big gap between the paddles and the housing.
On Ryan's, if you don't keep it fed full (shy of motor lug, but a little faster than you'd expect sometimes) it will not give distance, but on avg, I'd say 10-15' ish
  • Alc and hamman have said thanks
#3 Cat385B OFFLINE
    Tractorfanatics.com
  • 14749 Thanks
  • 10288 posts
Posted January 27, 2014 - 09:11 AM
5 feet is a problem. 3 inches seems to be enough to keep the blower fed to get some throwing distance. Did you try bumping it up to 3rd gear? Like mentioned you need to feed the blower enough snow to be at the point of nearly lugging the engine.
#4 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted February 04, 2014 - 08:57 PM
I have a snow blade off a MF #12 I'd sell ya! It's sitting in the shed in primer ready to be painted MF red! Pm me and we will talk! I'm located in Illinois.
