Ford 140
3 replies to this topic
#1 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted January 26, 2014 - 06:57 PM
Hello everyone I have a ford 140 with breakerless ignition and it is not charging any ideas? I was wondering if it is the voltage regulator.
Edited by massey 16, January 26, 2014 - 06:58 PM.
  • VintageIronCollector said thank you
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted January 26, 2014 - 07:42 PM
Could be, it could also be the ammeter or the starter generator. Simplier yet it could just be the wiring has a bad conection. I have the same problem on my Jacobsen Chief 800
#3 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted January 26, 2014 - 09:12 PM
This tractor has seperate starter and I believe it is a flywheel alternator. This tractor dosent have the belt driven starter generator. When on ampmeter shows little change but with electro hydralic deck lift ampmeter declines servely. Is there any way there is a problem with the fly wheel magnets? Ps the tractor runs perfectly I belive the ignition system works with the charging system on this tractor.
Edited by massey 16, January 27, 2014 - 07:19 AM.
#4 boyscout862 ONLINE
  • 12,544 Thanks
  • 9,043 posts
Posted January 27, 2014 - 06:59 AM
Check in the engine manual. You can download it from our Manuals section. There is also a good technical tip in our technical section on how to test your charging system. I doubt that you have both a started/generator and a flywheel alternator unless it is a newer engine. It is probably just a S/G with a regulator. Good Luck, Rick
