3 Point Hitch Lift
17 replies to this topic
#1 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 26, 2014 - 05:47 PM
    Where the hydralic arm attaches to this stotted piece. Should it slide through it or should it be tight enough to remain in the same spot and make the arm move?
How much movement should this arm have? Mine only moves maybe half an inch.
I fixed it for you Bill.
  • Texas Deere and Horse and Sawdust have said thanks
#2 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 26, 2014 - 05:49 PM
Sorry the 2nd pic is upside down :(
#3 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 26, 2014 - 05:52 PM
that's better
#4 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted January 26, 2014 - 11:18 PM
Bill, Mine slides as I lower the lift.
#5 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 27, 2014 - 10:00 AM
in both pics.....Why are the pieces slotted? Is it for adjustment sake?
#6 VTXrider OFFLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted January 27, 2014 - 10:11 AM
This slot is to allow the mower deck and rear implements to float as are the short slots on the pull arms. All those sliding and pivot points can be greased to reduce wear. Good time to grease the steering gears and zerks on the front axle. I also grease the lift carriage pivot points.
  • TheFarm2004 and Sawdust have said thanks
#7 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 29, 2014 - 06:26 AM
The piece the pull arms connect too. how much should it move? Mine only moves a few degrees.
#8 VTXrider OFFLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted January 30, 2014 - 03:40 PM
These pics show the travel of the rock shaft arm, about 45 deg. Hope this helps.
Edited by VTXrider, January 30, 2014 - 03:41 PM.
  • Sawdust and BillTribbitt have said thanks
#9 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted January 31, 2014 - 10:29 AM
it may only move a short distance with no weight. ad some weight to the 3pt(if equipped) and you should see a difference. if you dont something is binding or not hooked up properly.
#10 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted January 31, 2014 - 04:17 PM
the problem looks to be the arm on the ram. It just slides in the slot. Are there some kind of friction washers to stop that? It seems tight enough.
#11 VTXrider OFFLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted January 31, 2014 - 08:03 PM
The cylinder rod end is suppose to slide in the slot for the reason stated above. Stand on the draw bar to make it go down, you should see the full travel then. There is no down force from the cylinder, only lifting force. If you watch the rod of the cylinder retract and extend in the slot, it will only lift when it hits the end on the slot and that will be only a few degrees of rotation of the rock shaft arms, if there is no weight on the lift carriage like a mower deck or front plow.
#12 cityboy2977 OFFLINE
cityboy2977
  • 117 Thanks
  • 179 posts
Posted February 01, 2014 - 01:42 AM
if/when you have weight on the carriage or the 3pt and it doesnt move, THEN you have a problem.
like stated by VTX, it is slotted to allow the attachments to float.
picture this, your cruising down the driveway with a box blade on the rear, if the rear tires hit a dip the box blade will gouge an area of the driveway....you will never get anything level like that. now picture that scenario with every attachment made. hence the purpose of the float feature.
#13 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted February 01, 2014 - 04:55 PM
It works!!!!
dummy me......didn't notice the cutting height adjustment on the other side was all the way up and that was not allowing the hitch to drop any lower. Lowered it, stood on the draw bar and presto!!! Now if I could find a tiller attachment :)
#14 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted February 01, 2014 - 05:02 PM
Glad you figured out what was going on!
#15 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted February 01, 2014 - 06:36 PM
Glad you figured it out.  Unfortunately, tillers for these seem to be in big demand with very low supply. :(
