Bush Hog Implements For Bh Garden Tractors
19 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted January 26, 2014 - 11:11 AM
Thought a thread on the implements sold by Bush Hog for these garden tractors would provide good info for BH collectors. Post away
  • olcowhand, DH1, MH81 and 6 others have said thanks
#2 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted January 26, 2014 - 11:15 AM
ImageUploadedByTapatalk1390752728.435811.jpg ImageUploadedByTapatalk1390752773.228072.jpg ImageUploadedByTapatalk1390752792.010725.jpg DT-1 dump trailer AE-40 aerator S4244 Grader Blade 60" 3pt adjustable (Brinly BB-1000) S4248 28" Forks (for JB series tractors with 3pt hitch option)
Edited by sacsr, January 26, 2014 - 06:06 PM.
  • olcowhand, DH1, Texas Deere and Horse and 3 others have said thanks
#3 KennyP ONLINE
  • 36,468 Thanks
  • 44,944 posts
Posted January 26, 2014 - 11:32 AM
How wide is the blade you have there? Great pics of the goodies!
  • Littledeere and sacsr have said thanks
#4 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted January 26, 2014 - 12:00 PM
It's a 60" blade made by Brinly. It came with my JBI and the BH price list shows a 60" reversible - so this has to be it- BH showed Brinly implements in their brochures.
  • KennyP, Littledeere and boyscout862 have said thanks
#5 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 12:01 PM
Yes, their turning plows were built by Brinly.
#6 Texas Deere and Horse OFFLINE
  • 14,725 Thanks
  • 15,469 posts
Posted January 26, 2014 - 12:35 PM
Scott, this is a GREAT idea. I know that Bush Hog sold Brinly, Ark and some other Manufactures.
What all did Bush Hog actually build?
The Bush Hog built attachments I can think of are.
1. Mower Decks, Mid-mount, M-32, M-42
2. Pull behind T-42 Mower
3. 3pt Mower, S4240, S4242
3. Push Blade, FB-40A, FB-48
4. Snow Blower, ST-1, ST-330, ST-332, ST-348
5. Rotary Tiller, S3000
6. 3pt Sickle Bar Mower, S4243
  • DH1, MH81, Littledeere and 1 other said thanks
#7 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 12:39 PM
3 point rotary mower, model S4242.....42" cut.  Mine is the only one we know of at this time to still exist.  Former owner added the front depth control wheels, those wheels are OE  Bush Hog wheels, same as trailing wheel.
  • DH1, MH81, Alc and 4 others have said thanks
#8 Littledeere OFFLINE
Littledeere
  • 1,648 Thanks
  • 1,480 posts
Posted January 26, 2014 - 01:17 PM
What was the RPM speed for there rear pto,Brinly built many attachments for different makes and sometimes I think they have built just parts of them
Edited by Littledeere, January 26, 2014 - 01:17 PM.
#9 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 01:48 PM
ST-32 Regular Duty Tiller
ST-320 Snow Blower  36" Cut
  • DH1, MH81, Alc and 3 others have said thanks
#10 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 02:54 PM
I believe the rear pto on the JB series ran around 1000rpm, but I've never did a tach check to verify it.  I have a JBI with OE rear pto, so sometime I need to use my photo-tach to verify the speed.  I've never checked the D4-10's PTO speed either.
  • Littledeere said thank you
#11 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 02:58 PM
I am likely wrong on this pto speed.  The reduction unit for the HD-12 rear pto runs at 700 RPM, and since it uses the same implements as the JB for the most part, I am sure the JB's run the same speed of 700rpm.
  I would also suspect the D4-10 rear PTO turns the same 700RPM, as it too runs the same basic implements, such as the T-42 Trail Mower, and the same tillers the JB & HD series can run.  And I do know the pto shaft is reduced a good 4+ to 1.
  • DH1, Texas Deere and Horse, KennyP and 1 other said thanks
#12 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted January 26, 2014 - 04:59 PM
According to the price sheets the JB rear pto option turns at 700rpm as well, so Daniel you are correct as usual.
  • DH1 and Littledeere have said thanks
#13 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted January 26, 2014 - 05:04 PM
The manual I downloaded for the JBII Says 700 RPM. It & the JBI should be the Same.
  • DH1, Littledeere and sacsr have said thanks
#14 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted January 26, 2014 - 07:05 PM
I remember why I had 1000 to 1100 in mind on the pto rpm.  With my gearbox I used to put rear pto on my first JBI, that was about the slowest I could get using what I had readily available in pulleys.  For me that was figured at 3600rpm, but I run the TJD twin cylinder I installed on that tractor slower, so my pto rpm is likely around 800, which will work fine as well.
#15 Littledeere OFFLINE
Littledeere
  • 1,648 Thanks
  • 1,480 posts
Posted January 26, 2014 - 09:43 PM
Hmm what kind of shaft did they have,Thought JD had the only odd pto speed with the 400 tractors
