Wanted
Wisconsin S12-D Head
8 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted January 26, 2014 - 08:56 AM
No hurry but would like to find one as a backup- mine had the spark plug hole stripped and although it has been repaired, still want a back up. Thanks
#2 Littledeere OFFLINE
Littledeere
  • 1,638 Thanks
  • 1,470 posts
Posted January 26, 2014 - 10:39 AM
You might drop a line to  Old Path's Equipment {Ben } he has some Wisconsin stuff I beleive
  • sacsr said thank you
#3 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted January 26, 2014 - 11:05 AM
I was hoping one of our sponsor's might see this. Thanks
Edited by sacsr, January 26, 2014 - 11:06 AM.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted January 26, 2014 - 01:53 PM
Or members ?
#5 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted January 26, 2014 - 02:11 PM
Or members ?
Of course :-)
#6 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted January 26, 2014 - 02:13 PM
I have a parts S12D winnie,
#7 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted January 26, 2014 - 02:19 PM
I would be interested. Mainly just want the head but will consider it all - what's left on it?
#8 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted January 26, 2014 - 02:29 PM
Im thinking of keeping the starter/generator but could let the brackets go with the engine which is mostly there, has a special crank and PTO cover built to drive a air compressor, shared crank case oil type. Going by memory the piston, con rod, valves, lifter, cam and head all there, think the governor was removed but time has faded the memory. The rope recoil was removed but shrowd, flywheel is there, points removed, external coil im keeping along with the bracket bolted to the head that houses the starter switch, ammeter and ignition switch.
Would you require some pictures ? if so i will have to look deep.
#9 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted January 26, 2014 - 02:36 PM
Not as deep as i thought, still on the fence about selling it but here are pics :
Very heavy.
