Sold
Miller Roughneck Welder/generator
9 replies to this topic
#1 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted January 25, 2014 - 11:12 AM
Anybody have any interest in a old miller rough neck welder/generator? Believe this is a 3000 watt generator.Has a 12 horse kohler k301 that has a kohler sticker on it saying it was mini blocked at some point. Does need a little work, Motor runs, but I believe it some weak spark(probably needs a condensor which is less than a $10 fix) , will pop when it is running. I rebuilt the carb and it has a new spark plug. Has electric and pull start, but will not come with a battery. The welder part on it does not work, but there is a switch that has 2 wires disconnected, which is probably the problem. I haven't messed with it because I don't want to blow up the barn if I do something wrong. LOL Tires on it are in good shape, and i put new tubes in them, this is a really heavy duty unit if it worked well. If you got it working its probably worth double what I am asking.
$200 obo
Located in South Haven, MI
#2 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted January 25, 2014 - 12:04 PM
Hi,
Could you provide the model number and sn of the unit.
I'm trying to locate a manual to gauge interest and I need the identification info.
I'm located in Indiana, so not that far away.
Thanks. Chuck
  • JakeKuhn said thank you
#3 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted January 25, 2014 - 02:32 PM
Here ya go chuck...
model : Roughneck 1-e
serial : U515848
If you think you are interested make me an offer, I found something I would really like to buy and don't know how long it will last for sale.
Thanks, Jake
#4 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted January 25, 2014 - 02:53 PM
Here is the manual for it, might be a easy fix.
http://www.millerwel...m/o419f_mil.pdf
#5 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted January 25, 2014 - 04:15 PM
Hi Jake,
I would probably be interested in it at $100.
Chuck
#6 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted January 25, 2014 - 04:42 PM
chuck,
sent you a message.
jake
#7 dodge trucker OFFLINE
dodge trucker
  • 2,435 Thanks
  • 3,123 posts
Posted January 25, 2014 - 06:39 PM
if only you were closer Id take a chance on it... the engine don't scare me at all.  but the "non working generator half" does a bit
#8 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 25, 2014 - 08:23 PM
Jake you know you want it-go ahead, and & good luck with it.
Dick
#9 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted January 26, 2014 - 01:25 PM
I'll take 150 for this...but no less. The motor is worth that alone.  and if the welder doesn't end up fixable, which it probably is. There is a lot of scrap copper in there.
Would also trade it for a 48" wheel horse deck or blade, but not looking for other trades.
Thanks, Jake
Edited by JakeKuhn, January 26, 2014 - 01:25 PM.
#10 JakeKuhn OFFLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted March 12, 2014 - 07:43 PM
Sold
Also tagged with one or more of these keywords: Sold
