Walbro Lme 36 And Lme 57 Carb Question.
3 replies to this topic
#1 classic OFFLINE
classic
  • 5,177 Thanks
  • 2,234 posts
Posted January 25, 2014 - 09:36 AM
I just picked up a new walbro LME 57 carb that has an old core tag on it. The LME 36 I have is the original carb from my 69 Sears Suburban.If you look at the pic, you can see a small brass plug near the bottom of the choke butterfly on the LME 57 (the carb on the left).The plug has a small hole in the center restricting flow.The sears Suburban 12 LME 36 does not have this plug.Is the LME 57 with the brass plug intended for a smaller engine?
#2 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted February 09, 2014 - 09:08 AM
In my Walbro parts and service manual it shows the LME 57 as a carb for Allied Pacific and equipment list as a Drive cycle.Your LME 36 is listed for a HH120.The only difference is the venturi size.The 36 shows 21.80(mm),the 57 shows 19.05(mm).Here is the parts list and cross reference that shows the difference
Attached File  lme.PDF   2.64MB   64 downloads.
Edited by new restorer, February 09, 2014 - 09:09 AM.
  • classic said thank you
#3 classic OFFLINE
classic
  • 5,177 Thanks
  • 2,234 posts
Posted February 09, 2014 - 11:21 PM
Thanks for the info, I appreciate it. I disassembled both carbs and you can see the difference in the size of the venturi. Here is a pic of an LME 36 and an LME 34. Both have 55 cast into them and both are for the HH120.
Edited by classic, February 09, 2014 - 11:29 PM.
#4 classic OFFLINE
classic
  • 5,177 Thanks
  • 2,234 posts
Posted February 09, 2014 - 11:29 PM
Here is a pic of an LME 36 and an LME 57. The LME 36 has the 55 cast into it, and the LME 57 has a 48 cast into it. I'm guessing all LME carbs with the 55 cast into them will work on the HH 120.
