Ss14 Question
6 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted January 23, 2014 - 01:44 PM
Guys this is one of my wish list Gt's & my question is this. On some of these SS14 the front grill looks like it is missing the outside vertical piece on the right side. My thoughts are maybe this is removable for a take off belt like for a blower or rod for a front plow. I have seen some that has the vertical piece on both sides giving it a nicer look rather than looking like something is broke or missing. If a blower isn't being used is this piece available or a different grill needed. Thanks
Edited by Sawdust, January 23, 2014 - 05:26 PM.
  • MH81, hamman and boyscout862 have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 7290 Thanks
  • 3109 posts
Posted January 23, 2014 - 02:14 PM
I've never noticed that before. Having googled ss14 images I see that now. It does look as if the one piece is removable. I will be interested to find out as well. Good luck.  Roger.
  • Sawdust said thank you
#3 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted January 23, 2014 - 02:36 PM
Jim, your observations are correct, this applies to almost all the suburban models no matter the grill style. That piece comes attached stock and is removeable to use the blower and other front powered implements. Many times they are missing as someone took them off then they get lost or pitched.
Here is the SS15 I had that I sold, it has it. There is metal Mesh behind the side grill
Here is my 16/6 with the side piece removed, if I run mount the GM alternator, I can't use it so i leave it off.
Edited by TAHOE, January 23, 2014 - 02:38 PM.
  • hamman and Sawdust have said thanks
#4 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted January 23, 2014 - 03:24 PM
Yep, comes off for belt passage and many times PO doesn't have or know where it went. Very hard to find one used that guy wants to sell, cause of rarity I found when looking for one. Did find one later from a forum. Problem is there are lots of little bolts to remove and have nuts/washers all loose and is PIA, not a quick attach item like it should be.
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted January 23, 2014 - 05:30 PM
The piece is taken off for front mounted, belt driven implements... Specifically the blower. They do come up missing a lot. You've got to make sure the replacement is the right one because there are lots of variations.
On all of my tractors, it's a two bolt remove or install. Never seen one that was more than that.
#6 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted January 23, 2014 - 07:02 PM
Thanks guys I knew I would get a good response. A GT with this missing & no blower really looks like it's missing a tooth.  :(
#7 junkyardjeff OFFLINE
junkyardjeff
  • 99 Thanks
  • 107 posts
Posted January 25, 2014 - 06:49 PM
That green one looks familiar.Jim, your observations are correct, this applies to almost all the suburban models no matter the grill style. That piece comes attached stock and is removeable to use the blower and other front powered implements. Many times they are missing as someone took them off then they get lost or pitched.
