Tapping Into The Tractor Hyds
3 replies to this topic
#1 js5020 OFFLINE
js5020
  • 716 Thanks
  • 809 posts
Posted January 22, 2014 - 01:52 PM
I have an older CUT I bought new back in 84 and its been a great machine but its only ever had 3pth functions off the tractor hyd pump, and for years I have been using an elec/hyd power unit for aux functions,, well Ive had it with the power unit and would like to plumb a 2 spool valve into the system.  Anyone do this?  should I just cut the pressure line and T in a fitting?  Should I make a new pressure line run to the aux valve and from the aux valve to the 3pth valve?  Whats the best way?
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,450 Thanks
  • 10,178 posts
Posted January 22, 2014 - 07:37 PM
What's the diameter of the pressure line, and how much psi & gpm does that tractor put out?
#3 js5020 OFFLINE
js5020
  • 716 Thanks
  • 809 posts
Posted January 22, 2014 - 07:52 PM
The book says 5.4 GPM,  no clue on the psi the book doesnt mention it.  Dia of the line is .475 OD.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,450 Thanks
  • 10,178 posts
Posted January 22, 2014 - 08:10 PM
That seems to be plenty big, I would think tee'ing into that would work.
