Got A New Toy Today.
17 replies to this topic
#16 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted January 24, 2014 - 03:22 PM
Here you go .....
I'd check the Ignition switch , the contacts inside the switch sometimes oxidize and you won't get any voltage to the coil or points . You might try a heavy dose of contact cleaner where you put the key in and try turning it on and off a few times .
If your not getting voltage to the switch , it gets its voltage from the voltage regulator L terminal so the regulator may be bad .
Edited by Jlaws, January 24, 2014 - 03:52 PM.
  • suburban 12 said thank you
#17 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted January 24, 2014 - 05:50 PM
I put a new points wire on and used a test light as a hot wire. I managed to hot wire something back to working how it should, because before I used the test light it still wasn't getting spark. Now it has strong spark, and the plug and wire are good. It still doesn't want to fire, I am guessing that it is too cold for the starting fluid to vaporize fast enough to ignite.
Thanks for the suggestions and the wiring diagram.
#18 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 26, 2014 - 02:04 AM
Keep that starting fluid and use it for what it was made for, a diesel. Not a gasoline engine.
Get yourself a spray bottle and put some fuel in it to spray into your carburetor, that starting fluid can be pretty hard on these old engines. Ask me how I know this.
  • suburban 12 and JoeMopar have said thanks
