B80 Repower... What Engine?
24 replies to this topic
#1 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 21, 2014 - 04:01 PM
I was plowing with the B80 and sadly she went belly up. She started knocking and I began to head home because I was plowing down the street. And BANG. it threw the rod. It didn't go through the block but the cylinder wall is so out of shape it would be better to get another engine. I liked the lil 8hp but it was slightly underpowered. I was thinking 10hp kohler? or even do huge with a 14hp briggs opposed? I don't know! the possibilities are endless!
Any suggestions appreciated!
Thanks all!
  • A.C.T. said thank you
#2 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted January 21, 2014 - 04:47 PM
The k engine 10 or 12 should go in w/out any or few mods. Coils and regulaters won't be on that plate right behind engine like on the 8, but you can find places in dash like bigger C's have. 14 starts getting physically bigger and might be harder to put in. Battery tray issues maybe and not sure on hood clearance then. Don't think a twin is the answer and makes it harder with controls and such then too.
  • CubHorse80 said thank you
#3 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted January 21, 2014 - 05:21 PM
:iagree:
#4 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 21, 2014 - 05:38 PM
I was thinking a 10, im going to an auction on Saturday in Owensville and they are auctioning off 100-150 engines. so ill se what I can get :dancingbanana:
I was thinking about doing something crazy like a air cooled diesel or a twin 14-18hp if possible... but we will se what is at the auction :rocker2:  :rocker2:
  • trowel said thank you
#5 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted January 21, 2014 - 06:15 PM
I have a wheel horse with a 14 hp kohler factory. I love it.  It came with a 36 inch deck and it mows anything.
  • trowel and CubHorse80 have said thanks
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted January 21, 2014 - 06:19 PM
While bigger is sexier, you have to consider how much torque your drive line will handle.  Too much engine and you'll have a B80 lawn ornament.
  • trowel, twostep and CubHorse80 have said thanks
#7 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted January 21, 2014 - 06:45 PM
I would go with the Kohler 12 horse.
But this would be fun!
  • trowel, Traill95 and CubHorse80 have said thanks
#8 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 21, 2014 - 06:47 PM
:thumbs:
  • A.C.T. and CubHorse80 have said thanks
#9 js5020 OFFLINE
js5020
  • 711 Thanks
  • 807 posts
Posted January 21, 2014 - 06:55 PM
Yup,, the axle will likely be the favorite WH Unidrive but with 1" axles and 4 pinion diff,,,,, I have a 16hp K341 but I also have the 1 1/8 axles and 8 pinion diff.  I guess it depends on what you do with the machine,, an 8hp would be a real fuel mizer and have adequate power as a snow pusher or running a 36 deck,  I would think on rebuilding and know what you have rather than getting something unknown myself 2 hundy or so and you have a near new powerplant ready for another 40 yrs.
#10 Traill95 OFFLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted January 21, 2014 - 08:27 PM
I'm liking this... :rocker2:
#11 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 21, 2014 - 10:22 PM
I was thinking that but don't have the clams right now, but I have my eyes on a 12 HP Kohler magnum... it sin good shape and would suffice until I get mine rebuilt:rolleyes:
#12 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted January 22, 2014 - 08:50 AM
If you will need PTO power, don't forget how you plan to do that too...
#13 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 22, 2014 - 08:55 AM
GOOD POINT! :D
what is the shaft size i will be needing to put the existing pulley and pto onto? If i can find a deck i would love to mow!
#14 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 22, 2014 - 10:12 AM
However i do have a 2 cylinder kubota off a greens mower...
#15 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted January 22, 2014 - 11:04 AM
Well you shouldn't put it in that B80... you should sell it to me real cheap.
