Pushing Stuff With A Gravely
10 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted January 21, 2014 - 12:13 PM
I was bored one day and decided to see if my Gravely would push an old parts tractor I had that was in the way. I didn't think the Gravely would be able to do it because it has dual turf tires on each side and there was snow on the ground. I was surprised when the Gravely pushed it like the tractor wasn't even there.
http://www.youtube.c...h?v=I-4MSUMruqs
  • Alc, Texas Deere and Horse, HowardsMF155 and 3 others have said thanks
#2 HowardsMF155 OFFLINE
  • 2,970 Thanks
  • 3,019 posts
Posted January 21, 2014 - 12:54 PM
WoooHooo!
Gravely looks like its sure ready for more!  Glad it did the job for you, and thanks for posting the video.
  • farmerall said thank you
  • 14,889 Thanks
  • 15,514 posts
Posted January 21, 2014 - 01:10 PM
Matt, it didn't even change the sound of the engine, impressive to say the least!!
#4 farmerall OFFLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted January 21, 2014 - 02:38 PM
It runs great and has a ton of power. Now if I could only figure out why it likes to fry ignition switches. It's killed 2 so far and the 2nd was brand new. That one only lasted long enough to start the Gravely 10 times maybe.
  • 14,889 Thanks
  • 15,514 posts
Posted January 21, 2014 - 02:56 PM
Matt, I had one Kohler on a WH that the starter power went thru the switch, does yours use a solenoid?
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,142 posts
Posted January 21, 2014 - 03:04 PM
Sounds like that Gravely is also pushing it's luck.
#7 farmerall OFFLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted January 21, 2014 - 03:15 PM
Yes this one has a solenoid, basically your normal wiring setup for a Kohler engine with battery ignition.
#8 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted January 21, 2014 - 04:21 PM
Nice video. Those old Gravleys are beasts.
#9 MH81 OFFLINE
  • 29,979 Thanks
Posted January 21, 2014 - 06:29 PM
Sure wasn't taxing the Gravely. Good running tractor.
#10 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 21, 2014 - 08:28 PM
Can't beat a Gravely.  My 5260 gets worked pushing machinery, it has even pushed my antique ag tractors as long as I have chains on and I'm not going up hill.
Ben W.
#11 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted January 25, 2014 - 03:32 PM
Yea Those Gravely walk behind tractors have got lots of power.  You probably get thrown around if you don't have a good hold of the bars if you hit an immovable object?  Moved that tractor with no effort.
