Mig Welding Question.
30 replies to this topic
#16 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted January 21, 2014 - 09:22 AM
I'm sure if you ask 100 different people you will get 100 different answers... And of course I have a different opinion from the others. I think you main problem looks to be wire speed too fast. Turn the speed down to about 3.5 and see how it does.
I am 100% self-taught meaning I'm no expert... but my junk doesn't seem to break so I guess that is a good sign. One major tip I would offer is to only change one setting at a time.
Check out the attached pictures and my corresponding comments:
Red: Wire speed too way too high.
Green: Looks like good penetration.
Blue: Too cold or moving to fast causing the bead to MOUND instead of burn in.
Edited by twostep, January 21, 2014 - 11:05 AM.
  • Alc, Texas Deere and Horse, JD DANNELS and 5 others have said thanks
#17 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 21, 2014 - 07:14 PM
I spent some time this morning practising, with varied results.
One thing for certain, thanks to your advice/input hear, I payed
more attention to what I was doing. Checking my angle of attack, speed
of movement, and settings of the controls. I noticed more consistency in my
welds, I guess because of that.
I will keep practising, while I think up a project to burn up some wire on.
  • Alc, Texas Deere and Horse, sacsr and 1 other said thanks
#18 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 21, 2014 - 11:40 PM
  As I believe has already been said, practice, practice, practice. Read and understand the chart on the inside of the spool cover door. It will get you close to where you need to be for the thickness of iron you're welding and size of wire you're using. Another thing is be sure the circuit feeding it is not suffering excessive voltage drop especially if using an extension cord.
                                                          Mike
  • Alc, IamSherwood, HDWildBill and 1 other said thanks
#19 Alc ONLINE
  • 6,909 Thanks
  • 7,472 posts
Posted January 22, 2014 - 06:35 AM
Mike that's a good point about the cords , I bet the mig welders have a lot of electronics that aren't happy running on low voltage
  • IamSherwood said thank you
#20 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted January 22, 2014 - 06:44 AM
Will, one thing I do with my mig is make small circles as I weld. This seems to give a better appearance and makes sure I am burning into both pieces. And, if using an extension cord, make sure it is at least a 12 gauge cord.
  • sacsr and JRJ have said thanks
#21 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 22, 2014 - 08:11 AM
I've got get a real good extension cord yet, but for what I've been doing so far
I've made sure, I'm plugged into the wall.
  • KennyP, sacsr and JRJ have said thanks
#22 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 22, 2014 - 10:59 AM
Will, thanks for starting this thread.  Like you I'm just learning how to weld and your welds look a lot like mine. :D   I seem to ok on a straight flat weld but on an angle is where I'm having a problem
One question I have is do you need different tips for flux-core vs solid?
#23 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 22, 2014 - 08:25 PM
On this machine, yes. I would think so, on others too.
  • HDWildBill said thank you
#24 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted January 22, 2014 - 08:42 PM
I use the same tips on my Hobart. Just have to swap the wires to get correct polarity when going to flux wire.
#25 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted January 22, 2014 - 09:02 PM
Tips only depend on the wire SIZE, but the nozzle is different. You can use a gas shield nozzle for flux core wire but  you can't use flux core nozzle with gas shielding.
  • IamSherwood and HDWildBill have said thanks
#26 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 22, 2014 - 09:09 PM
I have a similar Welder which is set up for the Flux core wire. That's what I use.
It can be changed over to gas if I want.
Like Will, I made myself a good 50ft extension cord for it when I got it.
#27 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 22, 2014 - 09:58 PM
Yes, thanks for clarifying that. The nozzles are different, the tips the same.
  • twostep said thank you
#28 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 22, 2014 - 10:37 PM
One of the problems I'm having is when I'm welding the wire will quite feeding.  When I check it out I find the tip is the problem and I pull it off clean it out and put it back on and continue with what I'm doing.  What am I doing wrong?  I suspect I may be holding the gun to close to the work?
#29 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted January 25, 2014 - 10:27 AM
I weld for a living and see the heat way to high alto and that can make spatter and it can also be to much wire and not enough heat. for just about everything we weld at work i never change my settings 17.1volts 270 wire. we use Lincoln welders. also we never change gas pressure unless we are running co2. Argon oxygen welding is usually set at 40psi.
Don't be afraid to play with the welders first get comfortable with it
#30 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 25, 2014 - 11:11 AM
A lot of very good suggestions but the most important one is PRACTICE  --  PRACTICE --  PRACTICE.
Dick
