Mig Welding Question.
30 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 20, 2014 - 09:04 PM
This afternoon, I finally got to playing with my new Lincoln 140.
Can anyone tell me why I'm getting splatter seen in a couple of the
pictures?
  • hamman, sacsr, boyscout862 and 1 other said thanks
#2 MH81 OFFLINE
Posted January 20, 2014 - 09:07 PM
I see the gas, but is it wire that is meant for gas?
  • JRJ said thank you
#3 olcowhand ONLINE
  • 40,358 Thanks
  • 31,174 posts
Posted January 20, 2014 - 09:13 PM
Is the polarity correct for using gas?  The gun should be +.  On most, this is done by swapping cables inside where the wire feed spools are.
  • IamSherwood and JRJ have said thanks
#4 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 20, 2014 - 09:16 PM
Yes, L-56.
It only happened 2 or 3 times.
Settings in the 1st picture produced the weld in the 2nd pic.
Weld in the last pic, was produced with these settings. (same pcs. of material)
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 20, 2014 - 09:20 PM
Yes, did that.
#6 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 20, 2014 - 09:22 PM
Will, It looks to me like your holding the gun too far from the work and you maybe a little too high.
  • 14,730 Thanks
  • 15,470 posts
Posted January 20, 2014 - 09:23 PM
How much of angle are holding the gun at?
#8 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted January 20, 2014 - 10:16 PM
It doesn't look like spatter, it looks like you had the heat too high for your speed and it melted the wire before it got to the piece.
keep on practicing.
You're using solid wire and NOT flux core, right?
Edited by cookiemonster, January 20, 2014 - 10:16 PM.
  • HDWildBill and JRJ have said thanks
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 20, 2014 - 11:18 PM
You didn't state wire diameter. Stick w/ "c" voltage setting and play w/ wire speed and speed up your travel. You're piling it up too thick. Are you hearing the "sizzling bacon" sound?
JMHO,
Mike
  • Texas Deere and Horse, IamSherwood and HDWildBill have said thanks
#10 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 21, 2014 - 02:18 AM
Yes, changed that.
Around 30-35 degrees?? guessing.
keep on practicing.
Correct, I was using solid wire. I'll be burning it up practicing in the morning. Thks
JMHO,
Mike
.025 wire.  The sizzling bacon sound I heard on the better looking welds.
Thanks for the input guys. I'll play with it some more, and report back.
  • WNYTractorTinkerer and JRJ have said thanks
#11 KC9KAS OFFLINE
KC9KAS
  • 5,327 Thanks
  • 4,672 posts
Posted January 21, 2014 - 05:13 AM
Since some of the welds look decent, your settings are probably OK. Your welding speed and angle as well as distance from the work piece all make a difference in the look (and strength) of the welds.
Practice, practice, practice is the best advise.
Edited by KC9KAS, January 21, 2014 - 05:15 AM.
  • IamSherwood and HDWildBill have said thanks
#12 JDBrian OFFLINE
  • 9,609 Thanks
  • 14,144 posts
Posted January 21, 2014 - 06:05 AM
Too much stick out will do that. The welds look pretty good to me for the first time you've used that machine. That's a nice unit and available here for a reasonable price. Let us know how it's working out for you.
#13 Alc ONLINE
  • 6,744 Thanks
  • 7,397 posts
Posted January 21, 2014 - 06:21 AM
Could the drive rollers be slightly too loose ? I keep mine just tight enough that I can hold the wire back without making a birds nest inside the machine but sometimes it needs to be adjusted a little more  ( roller wear ? ) when I start having problems getting a smooth weld .
  • IamSherwood said thank you
#14 CRFarnsworth ONLINE
CRFarnsworth
  • 4,579 Thanks
  • 2,111 posts
Posted January 21, 2014 - 06:52 AM
Will,  Small wire (.025) = small weld. A rule of thumb is  If it has flux you pull it if it is hard wire you push it. (I break that rule all the time)  Gun angle, distance and hand speed are important.  Keep the nozzle close but not in your puddle you need the gas sheild flowing over the puddle for a clean weld.  Gotta go to work,  look forward to seeing your progress.  Rick
  • Alc, Texas Deere and Horse, IamSherwood and 1 other said thanks
#15 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 21, 2014 - 07:55 AM
Thanks guys.
Today I will practice, practice a lot.
I might watch the included DVD too.
