Bush Hog Slip Clutch
27 replies to this topic
#16 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 21, 2014 - 12:27 AM
That is ashame!!! At my last company they scrapped so many of these when they moved to China.
The company I am at now uses Torque Limiters on everything. But I don't think any are that style? I'll check to see just in case.
And you are right, these work opposite a clutch. These you want them to slip when to large of a load is applied (so nothing snaps), where as a clutch you don't want it to slip.
  • sacsr and boyscout862 have said thanks
#17 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted January 21, 2014 - 07:48 AM
Scott & Daniel, a suggestion. Scott ship the damaged part to Daniel and let him fix it for you. I'm sure there is something you two could work out for trade to do this!
  • olcowhand, sacsr and boyscout862 have said thanks
#18 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted January 21, 2014 - 08:03 AM
That would be fine with me Scott.  Nothing to work out....I'll just do it!
  • MH81 and Texas Deere and Horse have said thanks
#19 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 21, 2014 - 04:55 PM
Daniel and I got it worked out. As always Daniel comes through when you need him! Thanks Daniel!
  • olcowhand, Texas Deere and Horse and KennyP have said thanks
#20 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted January 25, 2014 - 07:01 PM
Scott, good thing I hadn't shipped you the NOS clutch just yet.  Turns out the NOS had a female receiver tube on the universal instead of a solid male shaft like you need.  Your old shaft's round adapter plate was beat out of shape, so I got it all hammered back flat & cleaned up a bit & bolted it to the NOS slip unit.  I'll ship it out next week.   This NOS slip clutch didn't have any hole drilled or tapped for an allen lock key, but right after I got it from you I took care of that.
  • sacsr said thank you
#21 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 25, 2014 - 07:28 PM
I glad mine got there first for sure!! I would struggled to figure out what was going on......why do you think it was made different??
Thanks for getting me back together!!  We still good on our deal or do I owe you some more??
  • olcowhand said thank you
#22 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted January 25, 2014 - 07:48 PM
We're mighty fine Scott.  I kinda wonder if you ended up with this NOS one because it wasn't built right from the start, so it could not be used.  Not drilled or tapped, then the tube welded on the wrong shaft end???  Your clutch likely got busted because someone used a square headed lock bolt instead of an allen set screw.  You can really torque down the square lock bolts.
  It doesn't matter what type end is on the shaft I use, as I have to build the other end of my shaft anyway, as I didn't get any part of the shaft/clutch with my tiller unfortunately.
#23 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 25, 2014 - 08:02 PM
I am running into something similar with the assisted lift spring kit. The crank will not go into the nut on the spring.....what is interesting is I have 2 more springs with nuts- the cranks will not fit them either. What I think happened is these springs actually fit the front plow. I am pretty sure I checked at some point and these nos springs fit the plows bolts/screws....where ever you call it. So I am guessing mistakes were made along the way?!
Edited by sacsr, January 25, 2014 - 08:03 PM.
#24 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 28, 2014 - 12:07 AM
Daniel I was looking at the ST-32 manual tonight and the slip clutch in the diagram is set up like yours with the female end. Hmmmmm, maybe mine was the one that was made the wrong way!
#25 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 29, 2014 - 07:48 AM
Now I am confused. I went to storage shed where I am keeping some overages as I get my shed in order, here is a picture of my ST-32 end of the tiller.......I may be missing something........
Edited by Texas Deere and Horse, January 29, 2014 - 11:51 AM.
Added photo wothout redirect.
#26 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted January 29, 2014 - 08:28 AM
Now I am confused. I went to storage shed where I am keeping some overages as I get my shed in order, here is a picture of my ST-32 end of the tiller.......I may be missing something........buga5uhy.jpg
That is a hollow square tube isn't it?  If so, I'd say you have everything correct.  With the geometry of the lift angles & such, I don't think there is much extension needed in the shaft at all, but then I've not set my tiller up yet to know.  In any case, you needed the clutch set up as I did it.  Maybe I need to wait to ship it??
#27 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,463 Thanks
  • 3,368 posts
Posted January 29, 2014 - 08:36 AM
Let me go back and get a measurement- Daniel measure the shaft on mine and let's see if they will slide together- never checked it since it all came with the tiller
#28 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted January 29, 2014 - 08:50 AM
Your original shaft that is now mounted the the NOS clutch is rectangular, 3/4 x 7/8".  The tube that is welded to the NOS clutch part as it was has a perfectly square ID of 1"
