Wheel Horse Electro 12 Stuck In Forward
8 replies to this topic
#1 keithservin OFFLINE
keithservin
  • 2 posts
Posted January 20, 2014 - 11:05 AM
My Elector 12 is stuck in forward happened while I was snowblowing-if anyone has iany info on how to repair this I would be grateful
  • 14,887 Thanks
  • 15,514 posts
Posted January 20, 2014 - 12:08 PM
Does the Hydro handle move and the tractor keep going, or is the handle stuck?
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted January 20, 2014 - 12:36 PM
Hello and welcome :wave:
#4 WH55 OFFLINE
WH55
  • 48 Thanks
  • 15 posts
I can't tell you how to fix it, but I did find this and download it for myself: http://gardentractor...-tranny-manual/
I hope that helps you :wave:
#5 GlenPettit OFFLINE
GlenPettit
  • 521 Thanks
  • 143 posts
Posted January 20, 2014 - 08:38 PM
Check the hydro release lever (small turn knob under your right knee on tranny, it may have unintentionally been turned),
that could have locked you into just one direction.
#6 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted January 28, 2014 - 10:00 PM
Fixed up yet?
Sounds like the ball stud on the direction control lever assembly may have popped out of the control cam plate on the front of the hydro pump.
It's a common problem caused by wear.
You'll need to remove the top panel on the lower part of the hoodstand to access that area.
  • keithservin said thank you
#7 keithservin OFFLINE
keithservin
  • 2 posts
Posted February 20, 2014 - 12:00 PM
Thanks WH1056-yes the plastic control plate was loose-one of the metal H brackets was loose-of course as luck would have it the starter crapped out-think i'm going to retire the Electro 12 to the showroom-just bought a Toro/Wheelhorse 522xi w/2 stage blower-54" deck with chute/bagger assembly-I know it's not a classic but I need some thing for serious blowing and mowing-live in the country with approx. 500' driveway and about5 acres grass to mow
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted February 20, 2014 - 06:52 PM
Good looking tractor. Shame a couple of things are wearing, but I'm 40 something too and it's happening to me also :D
#9 KC9KAS ONLINE
KC9KAS
  • 5,462 Thanks
  • 4,722 posts
Posted February 20, 2014 - 07:12 PM
:welcometogttalk:  Thanks for the photo of the Electro-12. It is a very nice looking machine.
