Ammeter Wiring Expert Needed
19 replies to this topic
#16 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,268 Thanks
  • 6,072 posts
Posted January 20, 2014 - 07:41 PM
The Ammeter is usually wired in series on the Charge wire from the Regulator's B+ on one side and the wire on the other side of the gauge goes to the Battery + terminal.  So it is in series in your charge wire. Make sense??
  • Mike125s said thank you
#17 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted January 21, 2014 - 04:19 PM
Is it necessary to put a fuse between the starter button/solenoid post and the ammeter?  Some tractors have this.  I do not see one on the parts list. Thanks
Mike
Genoa,IL
#18 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted January 21, 2014 - 04:26 PM
Mike
Genoa,IL
Additionally, my tractor does not have lights
Mike
#19 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted January 21, 2014 - 05:17 PM
If you have a big starter button, the BIG batt cables go directly thru that and not thru the switch and might not even have regulator??  No selonoid then either?  Meter just runs off a plus battery cable and is usually 10gauge, the -side goes to a key switch or other common junction and other wires go to the items to be powered by battery. Usually in a way that it is not on till switch is turned on.
#20 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted January 21, 2014 - 05:50 PM
It has a voltage regulator.  I think the big starter button functions kind of like a "manual" solenoid.  Starter button and key switch are seperate
Mike
