Bought A Truck Load And Trying To Figure Out What I Have
26 replies to this topic
#1 junkyard junky OFFLINE
junkyard junky
  • 64 Thanks
  • 58 posts
Posted January 19, 2014 - 10:21 PM
Wound up getting 6 garden tractors and a truck bed load of engines along with 2 snow blades. I need help with some of the engines. About half have serial numbers. It will take me a little bit of time to get all the pictures and info up. One of the Panzers is a hydro stat if I'm correct.
Engine 1
Engine 2
Engine 3
no numbers
Engine 4
no numbers
Engine 5
no numbers
Engine 6
no numbers
Edited by junkyard junky, January 19, 2014 - 11:21 PM.
  • Alc, jimbobbillyray, boyscout862 and 4 others have said thanks
#2 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted January 19, 2014 - 10:24 PM
Nice haul!
#3 Trav1s ONLINE
Trav1s
  • 3,316 Thanks
  • 4,368 posts
Posted January 19, 2014 - 11:10 PM
If the shroud info is correct on the green one you have a k301 = 12 HP 30 CI engine and looks to be from a Deere.
#4 farmerall ONLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted January 19, 2014 - 11:19 PM
Nice haul. Engine number 2 came from a Panzer tractor.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 14,011 Thanks
  • 10,013 posts
Posted January 19, 2014 - 11:22 PM
Trav is correct on engine #1 in your pics. That 'AS' code is a JD 140 coded engine, from the first year (1968) 140's only.
  • Trav1s said thank you
#6 MH81 OFFLINE
Posted January 19, 2014 - 11:29 PM
Number 5 looks like a tecumseh from a sno blower or a tiller.
#7 junkyard junky OFFLINE
junkyard junky
  • 64 Thanks
  • 58 posts
Posted January 19, 2014 - 11:48 PM
Engine 7
No numbers
Engine 8
Engine 9
Engine 10
I think this is a 39-41. Looks like a brass carb. I may be wrong. Type 60625 Model #7
Serial number 9587
Engine 11
Waukesha Motor Co Model # ICK 81 A    2 1/2 x 3 1/8
I was told it was a pony motor for a tank engine. Did some research and it says it could be from several different things.
Engine 13
Numbers AR6  208109    215463
Engine 14
I think this is a 1951 engine
Reo Motors Inc Model #211 Type E1 Serial # 70166
#8 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted January 20, 2014 - 12:28 AM
Well the one walk behind is a Bolens.
#9 DougT ONLINE
DougT
    Dog Approved
  • 6,930 Thanks
  • 4,997 posts
Posted January 20, 2014 - 02:12 AM
Engine #10 is a Briggs model Z instead of a 7. That 4 digit number may be older than 39. The brass Kingston was considered the high speed version. The pulley on it looks like Sears Handiman.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 20, 2014 - 04:49 AM
I see you have a Reo, very nice shape, let me know if you want to sell it.
Also see a Continental AU85, also in good shape.
#11 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted January 20, 2014 - 06:15 AM
Your number 11 does not look like any of my Waukesha ICKs. I have 3 that have up draft carbs, different magnetos and  the cylinder heads are very different from yours. The ICK was a very popular engine from the 30s through the 60s. It was used to power refridgeration on train cars, auxillary power on WWII bombers, powered pumps and generators, and as pony engines for large Waukesha engines. I suspect by the head that yours may be a special one that was used on racing boats. I've never seen one of those but read that they had a special cylinder head. You have a very cool collection there. Good Luck, Rick
#12 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted January 20, 2014 - 07:39 AM
Very nice good haul there
#13 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,803 posts
Posted January 20, 2014 - 08:50 AM
Serious haul you have there.
Lets see some pictures of the tractors.  In that one shot I see three Copar/Pennsylvania tractors and you're right, one looks like a hydrostat Meteor.
Edited by Canawler, January 20, 2014 - 08:51 AM.
#14 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted January 20, 2014 - 09:30 AM
Wow, what a haul!
#15 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted January 20, 2014 - 09:35 AM
Nice Haul!
Lets see some pictures of the tractors!
