Got Another Diesel In The Stables.
yanmar l60
38 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 18, 2014 - 10:28 PM
This might belong in the "other power equipment" forum but since I HOPE to put this engine on a small tractor I'm posting it up here. I did some trading around with some GT's and parts and ended up with this this Yanmar diesel generator and have nothing in it. I got it and the tanks bottom was rotted out, the fuel filter and pump was NASTY. I cleaned the pump, injector and lines, threw some fuel in a spare tank and here she is:
http://www.youtube.c...eature=youtu.be
Edited by twostep, January 18, 2014 - 11:10 PM.
  • olcowhand, MH81, Alc and 6 others have said thanks
#2 MH81 OFFLINE
Posted January 18, 2014 - 10:32 PM
Boy, it sounds like you got a great runner there.
What Hp is it?
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted January 18, 2014 - 10:38 PM
Sounds good. I think that's a 7.5hp yanmar?
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted January 18, 2014 - 10:44 PM
Sounds great. That will make a great project motor.
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 18, 2014 - 10:46 PM
From what I have found it's something like 6hp. It is the engine that the Chinese clones are based on. Like this: http://www.ebay.com/...=item27bcdc0f2f
PS: I realize just how country I sound when I say "Yayenmaar".
Edited by twostep, January 18, 2014 - 10:47 PM.
  • trowel said thank you
#6 MH81 OFFLINE
Posted January 19, 2014 - 07:45 AM
That not country, it's Southern Charm.
  • KennyP, trowel and twostep have said thanks
#7 JDBrian ONLINE
  • 9,606 Thanks
  • 14,142 posts
Posted January 19, 2014 - 09:10 AM
Those are the real deal and are what the clones were made from. The Chinese "borrowed" the design from Yanmar. It should be a good engine. I wonder what type of crank shaft it has. If that's a 1 bearing gen. head then it's likely a tapered shaft.
  • twostep said thank you
#8 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted January 19, 2014 - 09:21 AM
Great you got  it running :thumbs: . Do they run those small  diesel generators run at 3600 rpm like my little Homelite ?
#9 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 19, 2014 - 10:03 PM
here are some pic's.
  • olcowhand said thank you
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 20, 2014 - 09:20 AM
I checked and yes, the tag says 3600 RPM... I haven't researched how to convert it from constant speed to a throttle cable control.
The last picture above shows the shaft between the engine and the gen head. It appears to be a straight shaft on both the engine and the generator with a collar between them. One of these days when I get my other projects out of the way I split these two apart and check it out....
Until then, I've got a backup generator. One that should be really easy on fuel!
#11 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 20, 2014 - 11:00 AM
You got it, may be in mass but i am from southern Ohio.
You would be looking for a variable speed set up, contacting Yanmar or looking on ebay should yeild something, my Yanmar i converted to variable speed for use on mower.
As a gen set they are long run and durable. Run it wide open and use multi grade crank case oil, i use Kabota oil.
#12 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 20, 2014 - 11:20 AM
...my Yanmar i converted to variable speed for use on mower.
Do you have any pictures that you could share? I would like to see what you did.
#13 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 20, 2014 - 11:53 AM
Buried in shed, winterized, in Williamsburg, would have to dig it out, still very sick right now.
Here are some shots of two kinds, the older one with the lever and the newer sliding one.
The half moon siding one had a throttle cable holder and lock on the back of the hinged slider set up, perfet for the mower, it works like any throttle set up using a spring to the governor rod.
Looking for more photos of the convertion and parts no kit.
Forgive me, still feeling bad.
Forgot the photos , bottom two are the older hand throttle one:
Edited by trowel, January 20, 2014 - 11:55 AM.
#14 Cvans ONLINE
  • 6,458 Thanks
  • 6,053 posts
Posted January 20, 2014 - 12:59 PM
Nice find on the engine.
The link below is for the owners and parts manual. Looks to be down loadable.
http://www.masterpar.../100851-01B.pdf
Graingers should have been the distributor of Dayton products. Parts for the gen. set are
probably still available.
Have fun with your diesel. :thumbs:
  • trowel and twostep have said thanks
#15 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 20, 2014 - 01:29 PM
Cvens, was about to upload that, thanks.
Calling it a speed regulator but here is the older one : http://www.ebay.com/...781ac44&vxp=mtr
And here is the spring : http://www.google.co...1,d.cGU&cad=rja
Edited by trowel, January 20, 2014 - 01:32 PM.
Also tagged with one or more of these keywords: yanmar, l60
