1977 312
221 replies to this topic
#121 lyall OFFLINE
lyall
  • 2,023 Thanks
  • 1,526 posts
Posted August 07, 2015 - 03:51 PM
This is what Travis is getting
More picture if it after I power wash it.
yes the 312 came with side panels for a 200 series GT - which I am keeping.
Edited by lyall, August 07, 2015 - 08:56 PM.
#122 lyall OFFLINE
lyall
  • 2,023 Thanks
  • 1,526 posts
Posted August 07, 2015 - 08:56 PM
Here are the pictures
#123 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted August 07, 2015 - 10:24 PM
Wow!!!  That looks great after cleanup.
#124 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted August 14, 2015 - 06:38 AM
Off to pick up 312 #2 from Lyall later this morning.   :D
#125 lyall OFFLINE
lyall
  • 2,023 Thanks
  • 1,526 posts
Posted August 14, 2015 - 04:49 PM
Travis could not believe his eyes when he saw it.  I think he was in shock! He just stared at it not believing his eyes.
He looked it over and found the problem and said that he can fix it.
His dad was with him.  We sat and talked for a while and had a great time.
I told Travis to let me know when the 312 is fixed up and working again, so that I can go see it,( and kick myself in the butt for not fixing it myself.)  But I know it is going to a good home.
Showed Travis and his dad the two JD's a 210 and 212 that I had been rebuilding.  The 210 started right up and Travis said that it sounds good.
The 212 has a Walbro carb and it would not start and he said that he had problems with the Walbro carb too.  I had it running a couple days ago, but it was running the best.  I have a Carter carb that need a kit put in it, before it is running again.
  • Trav1s and hdg4400 have said thanks
#126 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted August 15, 2015 - 05:51 AM
It is quite nice and I think lyall took care of me.  Ok, he was real good to me.
The '78 312 arrived home and my dad and I could not leave it alone.  Swapped in the good battery from the 120 to see if it would turn over.  It did and it was strong.  Just for giggles we sprayed some MAF cleaner (because that is what I had handy) into the carb but it did not fire.  Checked the points and they were stuck together.  After a bit of cleaning and checking the gaps we had strong spark.  With a bit of gas into the carb thru a hose we cranked it over and it ran.  No smoke or funny sounds.   :D
One thing I noticed is that the '78 does not have the front hydro lines but the '77 does.  Also, the input shaft on the pump is bad on the '78 and good on the '77.  Looks like these two will get morphed together into a machine I will call the Frankentwelve.   :smilewink:
Edited by Trav1s, August 15, 2015 - 05:51 AM.
  • Alc, lyall, KennyP and 1 other said thanks
#127 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted August 16, 2015 - 08:36 AM
Pics of the input damage
#128 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted August 17, 2015 - 04:27 AM
Ouch!
#129 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted August 17, 2015 - 06:00 AM
I am going to split the '78 312 off into another thread since this project has taken a turn.
#130 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted December 07, 2015 - 10:37 PM
Hows it going?
#131 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted December 08, 2015 - 03:40 PM
Well, I spun the '78 off into another thread but ultimately here is the plan:
I will paint up the '77 frame, install the H-2 set-up from a 316K, hunt down and install the two-pedal brake set-up from a 317 to install, and put the best parts of the two together.  The '78 dash is in rough shape and the '77 will be easy to paint since it is apart.  I will also use the '78 fender pan when the '77 goes back together.  I will swap the strong k301 from the '78 into the '77 and the hot rod K301 in this thread will go in my 120.
When all this will happen is an entirely different conversation.
#132 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted March 11, 2016 - 05:36 PM
Bringing this one back...
I finally power washed the frame to 71632 (the 77) and I am going to strip it for a coat of blitz black paint. I will do the H2 conversion on this frame and go from there. I guess I like things to look the way I want them.
Edited by Trav1s, March 11, 2016 - 06:50 PM.
#133 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted March 12, 2016 - 11:04 AM
Baby is asleep and the wife is working so it is grinder time!!
Edited by Trav1s, March 12, 2016 - 11:05 AM.
#134 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted March 15, 2016 - 09:33 AM
Picked this up too.  It was one of those throw a bid out there and ended up with it much to my surprise.
Edited by Trav1s, March 15, 2016 - 09:34 AM.
#135 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted March 16, 2016 - 06:24 AM
What is it?
