1977 312
221 replies to this topic
#106 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted June 27, 2015 - 04:54 PM
Another long awaited update on this project...
Kirk shipped the crank and the rest of the parts I ordered - the package should be here Monday.   :love:
Edited by Trav1s, June 27, 2015 - 04:54 PM.
#107 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted June 29, 2015 - 10:29 AM
More pics later but here are a few parts of the k301 from Kirk including:
Clone Coil
Billet breather
Plug wire
Pointsaver
magnetic oil plug and a few other smaller parts
Edited by Trav1s, June 29, 2015 - 10:54 AM.
  • backwoods said thank you
#108 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted June 30, 2015 - 09:39 AM
Things that make me smile
  • wvbuzzmaster said thank you
#109 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted June 30, 2015 - 03:03 PM
Cleaned up the pan in prep for engine assembly.
#110 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 01, 2015 - 09:14 AM
So I found my tube of assembly lube and decided to lube up some stuff with it along with 30wt.  I pulled the cam and have decided to replace the .005 shim between the cam and the block.  Not sure where to get those but would guess Brian or Ben can hook me up.
#111 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 01, 2015 - 04:29 PM
Different clutch installed and adjusted according to the service manual and the behavior is still the same.  Time to check grounds and wiring harness again. :wallbanging:
#112 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 08, 2015 - 01:11 PM
Ignore the above post as it was for my 120 thread...
The new cam shim is on the way so I can continue with the build.
  • Navy Chief said thank you
#113 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 16, 2015 - 08:11 PM
Did some more work on the k301 today. Lapped the valves, installed the main bearing and crank, and will install the back plate and piston tomorrow. Since someone does not know how to read he had to remove already installed parts to do other work.
I'd fire my mechanic but he needs an excuse to avoid his job. :hitting_self_roller:
Edited by Trav1s, July 16, 2015 - 08:28 PM.
  • KennyP and Gabriel have said thanks
#114 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 17, 2015 - 04:27 PM
Got a fair amount done today in spite of the heat.  (I am glad the previous owner had ceiling fans in place in the garage)
- Bearing plate installed
- Piston and rod back in place (torqued to spec)
- Adjusted valves
- Oil pan on and torqued
-Head bolts cleaned and installed with head then torqued to spec
I did some more stuff and will add that later.
#115 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 17, 2015 - 06:56 PM
Pics before paint
Edited by Trav1s, July 19, 2015 - 07:39 AM.
  • Cat385B and Gabriel have said thanks
#116 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 18, 2015 - 10:17 AM
Managed to get a bit more done to the K301 this morning in spite of the 200% humidity of eastern Iowa. Tapped off the parts I wanted to leave bare and give the block a coat of JD Muffler black paint. I used it on my 120 and it handles heat, oil, and other grime without a problem. Following the paint I will add a few more Kirk parts to the engine and go from there.
Edited by Trav1s, July 18, 2015 - 10:30 AM.
  • Gabriel said thank you
#117 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 18, 2015 - 02:44 PM
A bit more work
#118 lyall OFFLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted July 18, 2015 - 03:06 PM
you did not paint the starter.  It is looking great.  almost to good to use.
#119 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted July 18, 2015 - 03:56 PM
I know... I probably will paint it since it looks bad next to all of the freshly painted parts.
#120 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted August 07, 2015 - 07:16 AM
Bringing this back up - lyall was watching out for me yesterday and I will head west to his place next week.  He has something that will help with this project.   :smilewink:
