1977 312
221 replies to this topic
#16 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted January 26, 2014 - 04:04 PM
So I stopped at the house and picked up my 300/312/314/316K service manual and found this picture of the 312 with the grill installed:
Looks like it needs the later style bar grill painted green.  That is much easier to find than the earlier wire grill on the 300/316K machines.
#17 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 04, 2014 - 08:10 PM
Just bringing this back up to the top...
Swapping the seat from the 140 over to the 312. I also started working on the fiberglass hood which has received previous repairs. I am considering a replacement. Here are a few pics:
Edited by Trav1s, September 04, 2014 - 08:13 PM.
#18 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 05, 2014 - 10:13 AM
Going to pick up another hood from Lyall and might save this project for later.
  • Navy Chief said thank you
#19 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 22, 2014 - 04:43 PM
A surprise bump on the 312 thread!
A member of my church is starting the diesel mechanic program at the local community college.  He wants to use the K301 as a project.  I need to get the parts and he (with the help of his instructor) will go through it.  Any suggestions where to get GOOD parts?  I am not sure if it will need bored and I am pretty sure the rod broke before it was parked.  This one is getting set up for duty with the 49 blower.
Supraben are you out there?
Edited by Trav1s, September 22, 2014 - 04:44 PM.
#20 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted September 22, 2014 - 05:36 PM
So they are going to build you a 'blown' K301?
#21 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 22, 2014 - 06:00 PM
Smartphone fail - rebuild the k301
#22 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 22, 2014 - 10:05 PM
then again the visual image of a GMC 6-71 on a dozen K301s is quite amusing.
#23 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 23, 2014 - 10:35 AM
I think a bit of the Kirkengines.com Killer Kohler info will get incorporated in the k301 along the way.
#24 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 23, 2014 - 10:55 AM
Travis, Our Sponsors here most all carry OEM and after market Kohler parts. I also use NAPA for some of mine because I can get them quicker, usually the same day or the next, they also carry after market parts.
  • Trav1s and backwoods have said thanks
#25 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted September 29, 2014 - 10:59 AM
The rebuilder removed the pan and found that it tossed the connecting rod at suspected. When it broke it also wiped out the oil splasher. He pulled the info on the engine and I am am pretty sure it is the original k301 to the tractor with a '77 production date. The class instructor suggests a .010" overbore since there is some scoring in the cylinder wall. I do know in the past it received a light hone with a new rod and piston. The crank also needs turned .010" under which I am guessing is why it threw the rod the 2nd time. This one does NOT have the balance gears. Woohoo!
My parts list so far includes:
- .010" piston
- .010" rod
- gasket kit
- Kohler/Carter 26 carb
Considering the following mods while it is apart:
- Roller crank bearings (from MidwestSupercub which is about 40 miles from me)
- Kirk crank weight
- Kirk Pointslayer
- Kirk Billet engine breather cover
Edited by Trav1s, September 29, 2014 - 02:25 PM.
#26 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted October 01, 2014 - 12:11 PM
Got some news on the engine today.  It seems it was bored in the past and will take a .020" over to clean up the cylinder walls.  Here are some pics for reference.
Edited by Trav1s, October 03, 2014 - 09:49 AM.
#27 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted October 06, 2014 - 05:46 PM
Parts went to the machine shop today.  The shop is going to check valves, guides, and other stuff.  I told them I want to do it right the first time.  More info from the shop later in the week or the beginning of next.
#28 Bolens 1000 ONLINE
  • 14,928 Thanks
  • 18,113 posts
Posted October 06, 2014 - 05:51 PM
If this helps anyone I can get Genuine Kohler or aftermarket parts .....
#29 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted October 11, 2014 - 08:51 AM
Got word that the bore on the block are beyond specs and cannot be saved.  It also significantly damaged the block when it tossed the rod and the crank is out of spec.  Time to find a different block and continue the project.  The only bad thing is that this original block did not have the balance gears.
#30 REdington OFFLINE
REdington
  • 11 Thanks
  • 11 posts
Posted October 13, 2014 - 01:37 PM
Hey Travis,
 I may have a lead on a 301 for you. I'll find out more tomorrow. I'll PM you with the details when I get them.
Rodney
