1977 312
229 replies to this topic
#136 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted March 16, 2016 - 06:45 AM
It is a cover for the three-point notch in the fender pan.
  • KennyP and propane1 have said thanks
#137 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted August 24, 2016 - 10:00 PM
So I have tried to find this one a new home and don't want to give it away so i still have it.  My plan as of today is as follows:
- strip and repaint the '77 frame
- update steering like I did on my 120 (ordered new tie rod ends today)
- install new motor mounts
- swap engine from '78 312 (AKA Frankentwelve)
- use best body parts to make the '77 312 a solid worker
#138 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted August 24, 2016 - 10:01 PM
I also picked up a late 2 blade 38 deck on a 318 that I hope to install on this machine for yard work until my 318 is done.
#139 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted August 25, 2016 - 06:45 AM
I also picked up a Kohler/Carter 26 carb for this one for the grand sum of $10 + shipping.  Anyone need a Walbro?
#140 KennyP OFFLINE
  • 40,236 Thanks
  • 46,811 posts
Posted August 25, 2016 - 07:00 AM
Is it still good? I like the Kohler/Carters better, but could work in a pinch.
#141 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted August 25, 2016 - 07:02 AM
Tractor runs fine with it but has a stumble as it transitions from idle to WOT.  After my Walbro experience on the 120 I have vowed to be Walbro free ASAP.
  • KennyP and Navy Chief have said thanks
#142 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted August 28, 2016 - 07:31 AM
Carb arrived and disassembled for rebuild.  i need to order the parts later today.  I also picked new tie rod ends like I used on the 120.
#143 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 03, 2016 - 09:09 AM
I have new replacement isolators from an ebay seller that arrived this week.  They look close on top but appear different on the bottom.  I will snap a few pics for reference.  I am concerned about the differences but have an idea that might help make them last.   I have been thinking about the suggestions lyall gave me which I think would be great on the belt drive 200 series but think the early 300 series is a different monster with the solid-mount drive shaft.  I am also going to replace the front ones with pieces from Deere but struggle with the cost of $56 each.  Then again, Deere pieces are cheaper than replacing an input shaft on a pump.
Edited by Trav1s, September 03, 2016 - 09:12 AM.
#144 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 03, 2016 - 09:14 AM
Harbor Freight has a 25% off coupon for Labor Day so I am going to pick up a small ultra sound cleaner, address some of the problem areas with caulk, and use that to give the carb a good cleaning.
http://www.harborfre...eaner-3305.html
#145 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted January 16, 2017 - 04:18 PM
Long overdue update...
My daughter has claimed Frankentwelve as her own and we have decided to call him Frank.  We played around with Frank in November's unseasonably warm temps and she had fun.
I have also been picking up parts and doing work as time allows.  The parts I have picked up include Deere front engine isolators and I am still looking for a reasonable independent brake setup to install while it is apart.
  • backwoods said thank you
#146 KennyP OFFLINE
  • 40,236 Thanks
  • 46,811 posts
Posted January 16, 2017 - 04:37 PM
She looks like she's ready to go Dad! I used to have a bookmark for those type isolators, but it seems to be missing. Found them when looking for the Ford type.
#147 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted January 16, 2017 - 04:40 PM
daddy it is my turn
lets go
  • Trav1s said thank you
#148 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted January 16, 2017 - 05:17 PM
daddy it is my turn
lets go
I let her drive while walking along side the tractor and holding her on the seat.  :D
  • lyall, KennyP and hdg4400 have said thanks
#149 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted March 01, 2017 - 09:55 AM
I found a complete set of steering brakes from a 317 that is close to me.  I will pick them up next week and hopefully get to work on the '77 frame once again.  I am dealing with some serious spring fever and every time the weather warms up I am buried in work or out of town.  The other bonus of the trip is that I can pick up some lovely New Glarus brews while in Wisconsin.
Edited by Trav1s, March 01, 2017 - 09:57 AM.
#150 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 643 Thanks
  • 460 posts
Posted March 01, 2017 - 11:49 AM
You can get the rubber mounts from McMaster-Carr cheaper then from Deere, got a set for my 78 316 and a set for my uncles and I two 212's. I like them better because they have four holes drilled in the metal plates instead of two, this allows you to use a extra bolt or rivet when you mount them to the frame.
