Wheel Horse Attachments
6 replies to this topic
#1 cubbie OFFLINE
cubbie
  • 1 posts
Posted January 18, 2014 - 07:44 AM
I am looking at purchasing a newer b series wheel horse and am wondering if my c series snow plow will fit . thanks
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted January 18, 2014 - 08:19 AM
:welcometogttalk:
There is an interchange list here : http://gardentractor...t-1955-to-2000/
You might need to know your plow model number, but maybe this list will help.
#3 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted January 18, 2014 - 08:21 AM
:wave: Welcome to the forum! Hope you post some pics of the new addition!
#4 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted January 18, 2014 - 08:25 AM
Welcome to GTtalk! Hope you enjoy the place!
#5 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted January 18, 2014 - 09:30 AM
:welcometogttalk: , and :wewantpics:
#6 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted January 18, 2014 - 10:37 AM
Welcome to GTT. Relax and enjoy the site. Check out the Manuals Section for 3 free downloads per day. Good Luck, Rick
#7 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted January 18, 2014 - 11:36 AM
I've had one on both. There is a Short Frame version where the understructure is kinda A shaped from blade pivot to back axle, then there is a Long Frame one that has about foot and 1/2 of straight section at back before axle. Both go back to the axle and you must have that special mount that bolts over the axle square axle tubes to slip the big rod at end of frame into and lock down. That stays on the tractor at other times and so many times a blade gets sold w/out the mount. Can't mount it with out that axle mount. B series were short frame for awhile I guess, but mine were the long frame. BUT, I have had both blades on mine. The blade May hit the tires if frame too short when trying to turn blade. OR, if not static, maybe when pushing a load.  The link in center of the blade goes up to the rockshaft under tractor. It can be a solid rod with adjustment or just a chain with adjuster. The chain won't let you have down-pressure on blade, but I never saw a problem with that. These little guys can really push, need chains tho, and you'll love the easy steering Horse's have to manuever.   Also, manuals might have same blade frame for tractor, but at times different size Blades in width mostly.
