My Massey 14 Is Home
198 replies to this topic
#196 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted June 26, 2014 - 08:30 PM
Clean it good & lightly coat it in something like flour or talcum powder.  If it is cracked or leaking, you'll know where soon enough.
I haven't put the cylinder back together yet, but maybe if I run it through the parts washer and try what yo suggest, maybe that will tell me?
#197 New.Canadian.DB.Owner OFFLINE
  • 2551 Thanks
  • 1620 posts
Posted June 27, 2014 - 07:54 AM
Not sure, but it's worth a try.  The purpose of the flour / talc is to absorb the fluid leaking out of the cylinder & give you an identifiable wet spot, aka the crack. Not sure if it will work without fluid leaking out, but maybe some will be trapped in the crack & wick back out with the coating.
  • Gabriel said thank you
#198 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted June 28, 2014 - 09:10 PM
Today, got some cleaning done on the engine block and oil pan. Not to far from being ready to send the block to the machine shop!
  • Sawdust said thank you
#199 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted July 02, 2014 - 10:16 AM
good luck  on the block
