My Massey 14 Is Home
198 replies to this topic
#181 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 08, 2014 - 08:49 AM
Are you having a seat made? Often, reupholsters can do stuff like that.
No, I bought an A&I brand seat. Thanks anyway!
#182 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 08, 2014 - 08:51 AM
SEM paints are made for auto interiors.
Thanks, I might check in to it.
#183 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 08, 2014 - 08:52 AM
cannot wait to see pics of your progress
Thanks! I'll post some as soon as I have time to do a little work on it.
Edited by Gabriel, May 08, 2014 - 08:53 AM.
#184 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 12, 2014 - 08:02 PM
I bet she is looking sweet...
  • Gabriel said thank you
#185 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 12, 2014 - 09:20 PM
The only thing that looks sweet so far, are the new parts that aren't rusty, or greasy, or dirty! I sure do look forward to really getting started on the restoration process!
Edited by Gabriel, May 12, 2014 - 09:22 PM.
  • Sawdust said thank you
#186 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 15, 2014 - 06:43 AM
Im sure before long it will all be a real nice piece.
#187 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 16, 2014 - 09:50 PM
Today, I started to remove the came shaft. Maybe tomorrow I can finish. I called our local CARQUEST, and the man I talked with said that he can bore, hone and clean (at least the inside) for $60-$65. I will probably go with them.
Edited by Gabriel, May 16, 2014 - 09:51 PM.
#188 Sawdust OFFLINE
Sawdust
  • 6794 Thanks
  • 3799 posts
Posted May 16, 2014 - 10:50 PM
That sounds like a good deal, let us know how it works out.
#189 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 19, 2014 - 08:48 PM
not a bad deal at all. I"d do it ...
#190 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted May 19, 2014 - 10:29 PM
Thanks guys!
Edited by Gabriel, May 19, 2014 - 10:29 PM.
#191 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted June 25, 2014 - 09:25 PM
A couple of weeks ago, I degreased the front axle and the part of the front grill that I will use. My uncle is going to bore out the main pivot on the front axle and add grease fittings for all the pivot points on the axle. He will also get bushings for the axle (and maybe install them). I found a place in Wisconsin that supposedly has the seals for the hydraulic cylinder, and the repair kit for the hydraulic valve! I've got all the parts of the valve and cylinder pretty well clean (for some reason, the cylinder body seamed a little oily even after running it through the parts washer). I did finally get the valves removed from the engine!
Edited by Gabriel, June 25, 2014 - 09:26 PM.
#192 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted June 26, 2014 - 06:51 AM
sounds like your making good progress
#193 New.Canadian.DB.Owner OFFLINE
  • 2551 Thanks
  • 1620 posts
Posted June 26, 2014 - 06:27 PM
... (for some reason, the cylinder body seamed a little oily even after running it through the parts washer). ...
Does it have a hairline crack?
#194 Gabriel OFFLINE
Gabriel
  • 1453 Thanks
  • 1868 posts
Posted June 26, 2014 - 08:20 PM
I'm not sure. I suppose it's possible.
#195 New.Canadian.DB.Owner OFFLINE
  • 2551 Thanks
  • 1620 posts
Posted June 26, 2014 - 08:26 PM
Clean it good & lightly coat it in something like flour or talcum powder.  If it is cracked or leaking, you'll know where soon enough.
