My Massey 14 Is Home
198 replies to this topic
#166 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 27, 2014 - 02:10 PM
I would check it out
  • Gabriel said thank you
#167 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted April 27, 2014 - 02:48 PM
Should I replace the bearings (crank shaft bearings, etc.), while I have it apart?
I always felt like once you get that deep into an engine just do a complete overhaul. Your like me theirs plenty of money to be spent but sitting on a GT knowing the engine is the best it can be would be a comfort.
  • IamSherwood and Gabriel have said thanks
#168 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 27, 2014 - 08:38 PM
I need to find a source for quality main bearings, as the Kohler ones cost $110!
#169 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 27, 2014 - 09:57 PM
I had an idea, I thought it might be neat to paint the MF "triple triangle" on my new seat, (on the steering wheel side of the back rest) just like the new MF Ag tractors have the "triple triangle" sewn on the back rest. Is there a special kind of paint that I should use? I'm not sure that I will, just pondering. I do want to paint the back side of the seat red, like the original would have been.
Edited by Gabriel, April 27, 2014 - 09:58 PM.
#170 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 29, 2014 - 04:20 PM
Gabriel,
check out Stens replacement parts.  I have had good luck with there replacement parts .  They run about 1/2 the cost of Kohler parts.
Gabriel,  a good source is stens.  I and many of my friends have used stens replacement parts with no problems.  they are about 1/2 the cost of Kohler
#171 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 768 Thanks
  • 639 posts
Posted April 29, 2014 - 07:40 PM
I'll be honest, I don't think you're gonna find a paint that will stick well to the vinyl seeing as though it flexes when you sit against it. The paint will probably just rub off. Just spend the $ and have it embroidered on lol just kidding!
Sent from my GT-I9300 using Tapatalk
#172 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 29, 2014 - 10:07 PM
I wondered about that. I wasn't sure if I really wanted to do it, as it's not how it would have been originally.
  • GTpicker01 said thank you
#173 Gabriel ONLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 29, 2014 - 10:09 PM
Gabriel,
Thanks, I'll check in to it! I've used some Stens parts on our power equipment, as well as some of my customers.
Thanks, I'll check in to it! I've used some Stens parts on our power equipment, as well as my customers.
Edited by Gabriel, April 29, 2014 - 10:11 PM.
#174 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 30, 2014 - 09:50 AM
Gabriel
are you going to do a valve job while its apart?
#175 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 30, 2014 - 08:54 PM
Gabriel
Yes.
I found a website that has aftermarket crankshaft bearings for $20! I need to see if the original bearing has any numbers on it, as it may be a common bearing that a bearing store would have.
Here is a link to the site: http://gardentractor....com/engine.htm  It's a site for pulling GTs, but they have a lot of good info about engines.
  • Sawdust and GTpicker01 have said thanks
#176 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 05, 2014 - 01:05 PM
great plan
Gabriel
#177 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted May 05, 2014 - 09:23 PM
great plan
Gabriel
Thanks!
#178 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted May 05, 2014 - 10:23 PM
Are you having a seat made? Often, reupholsters can do stuff like that.
#179 pianotuner OFFLINE
pianotuner
  • 92 Thanks
  • 140 posts
Posted May 06, 2014 - 12:11 PM
SEM paints are made for auto interiors.
#180 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 07, 2014 - 12:29 PM
cannot wait to see pics of your progress
