My Massey 14 Is Home
198 replies to this topic
#151 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 02, 2014 - 09:08 AM
Holly OMG what a "lack of cleaning program" the previous owner
had going on with that engine.
How does the bore look? Hard to tell in those 2 pics, but nothing
obvious there.
You may get away with just rings and gaskets.
It will take a lot of cleaning. The bore seems to be smooth, though I have not checked to see if it's out of round or tapered. As you can see in the picture of the cylinder, it appears that the poor compression was primarily caused by blow by. It would sure be nice to only have to replace rings and gaskets!
Should I replace the crank shaft bearings, or any other bearings, while it is all apart?
#152 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 02, 2014 - 09:13 AM
A lot of carbon on the head gasket maybe a leak? Can you salvage the piston? Looks like you had some bad rings too. I'm debating whether or not to rebuild my Tech 12 on the MF it runs good but I would feel better if I did.
I hope I can salvage the piston. It supposedly smoked, so it was one of my top priorities to rebuild the engine (primarily for my health) (did not want to breath the smoke!) When we found out how bad the compression was, and that there was blow by, I'm glad I did not decide to let it go for a while.
Edited by Gabriel, April 02, 2014 - 09:14 AM.
#153 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 02, 2014 - 07:23 PM
Gabriel
looks to me like you have a project . Iam sure you will get it running again way better than before.
  • Gabriel said thank you
#154 New.Canadian.DB.Owner OFFLINE
  • 2564 Thanks
  • 1628 posts
Posted April 02, 2014 - 07:53 PM
I was surprised how well the hone works on my Wisconsin ABN.
#155 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 02, 2014 - 09:29 PM
Gabriel
Thanks Rob!
Edited by Gabriel, April 02, 2014 - 09:31 PM.
#156 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 03, 2014 - 05:33 AM
keep the updates coming , and pictures too.
#157 KennyP OFFLINE
  • 51846 Thanks
  • 52913 posts
Posted April 03, 2014 - 06:46 AM
After looking back at the pic of the piston, I would say the oil rings are worn out. If the bore checks okay, give it a good hone and new rings.
#158 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 03, 2014 - 07:44 PM
Gabriel
hopefully that's all it needs just tweak it a touch and put it back into service.
#159 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 03, 2014 - 07:50 PM
Gabriel
Thanks, I hope so! I want to do things right, but the less money spent on it, the better.
#160 Gabriel ONLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 03, 2014 - 07:53 PM
Should I replace the bearings (crank shaft bearings, etc.), while I have it apart?
  • Sawdust said thank you
#161 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 03, 2014 - 08:56 PM
Iam sure you'll find lots of places to put the extra money some where in the tractor.
#162 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 20, 2014 - 09:08 PM
I did do a little checking the other day on the bore. There was at least one place that I could start to stick a .014 feeler gauge between the piston skirt and cylinder wall. It seems tighter at the top and bottom of the bore.
#163 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted April 21, 2014 - 06:41 AM
Sounds like it might be a little egg'd at the bottom. Do you have access to a T gauge set or something else the would accurately check the bore?
#164 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 21, 2014 - 08:34 AM
No, I don't. I wonder if O' Reilly Auto Parts would loan me one?
#165 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted April 21, 2014 - 10:24 AM
Worth the phone call
